Paradise Builders - Page 75 - diyAudio
Old 2nd January 2013, 07:18 PM   #741
Joachim Gerhard's Avatar
Maybe the reason for the offset is that the output buffer is floating.
Guys, connect a 20kOhm resistor from the output of the buffer to ground.
Old 2nd January 2013, 07:31 PM   #742
studeb is offline studeb  United States
studeb's Avatar
Like pin 6 to pin 7?
Old 2nd January 2013, 08:24 PM   #743
From JP2a to JP2b. Simply from output to ground.
Old 2nd January 2013, 08:36 PM   #744
studeb's Avatar
ah, i was overinterpreting
thanks
Old 2nd January 2013, 08:59 PM   #745
OK, lets try this.
Old 2nd January 2013, 09:11 PM   #746
studeb's Avatar
How about just connecting it to the pre. If there is a resistor across input, would that do the trick?
Einen guten rutsch!
Old 2nd January 2013, 09:16 PM   #747
That should work too and may be the reason that the beta builders had not much trouble with DC offset. If this is the reason then i am sorry that i forgot the bleeder resistor.
Old 2nd January 2013, 09:19 PM   #748
studeb's Avatar
easy enough to put one in.
Actually that is why you put in duplicate output pads.
Right?
Old 2nd January 2013, 09:23 PM   #749
We put in a lot of options. Sorry, i get a bit old and can not remember all the details.
Old 3rd January 2013, 09:58 AM   #750
Default uncomfortably hot
Hello,
I am nearly at the point to hook the Paradise to my setup.
I've got everything working, but after having it for 2 hrs.
on the mains I realized the frightening temperature of the
heatsinks.
I can touch them only for seconds.
I run in the regulator with about 29 volts, that should be ok.
But I don't like to burn my house down on accident.
Is there a easy way to get the 29 v a little down to have a
little more headroom regarding the heatsinks?
Thanks,
Christoph
[IMG]Click the image to open in full size.[/IMG]
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright 1999-2017 diyAudio
