| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#701 |
Hello guys and a happy and healthy new year.
Yesterday I found a little time to try a first seating test in the enclosure, I have taken 2 pics [IMG] I beg you all to have a look at my posting #682, where I told of my 3 problems. I have no idea what to do to fix them. I truly like to run my paradise, regards, Christoph |
#702 |
Christoph, if the layout you have shown is a MC preamp, it must have hum and buzz like a hell. MC preamp is one of the most difficult audio components regarding wiring, shielding, grounds, pickup of magnetic field from transformers. I hope someone who designed this project would also give some recommendations and construction hints. My hint is to keep the input of the MC preamp as far as possible from any transformer and avoid any loops (loops of analog ground).
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#703 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
For those who have Fairchild BC327 and BC337 devices, measurements below show they can be matched with devices from ON Semi purchased from Digikey. Now that this is done, it is time to return to my Paradise build.
*hFE approximation using the circuit shown in Post #72. All measurements made at room temperature with fan blowing on transistor. Happy New Year to all! Pierre |
#704 |
Output offset should go down after caps settle.
RC |
#705 |
Do they really need to to "settle"? I guess I have built hundreds of DC servos and caps never needed to "settle". They only needed to charge during RC time constant, this should last no more than seconds with max. like 10s.
#706 |
The "settling" that happens is the input caps (elcaps, connected in series with the cartridge and they have DC). It actually is like Ricardo is describing, let them settle (turned ON) for a couple weeks and see what happens
#707 |
Just been putting together the first board of a Paradise brace and I'm having a couple of problems.
The power supply side is working fine, providing the +/-18V quite steadily. I'm measured voltages at the test points as in the pdf for the schematic linked in this thread. The picture below (which may be a little large, but lots of detail!) shows the results. Shame the text is too small ![]() ![]() I firstly had a problem with a couple of solder bridges on transistors, I've highlighted those. I did power the board with the bridges in place so the transistors may be damaged. I removed the bridges, but not the transistors. I misplaced a BC327 instead of a BC337 (Q51 I think - don't know my way around the board yet!). Again, I powered the board before I spotted the problem. The problems I'm seeing are: Output is at -10.9v The EXT RIAA is at -12.5V TP9/TP10 measure at -13V Q22 (BC327) and Q18 (BC327) run very hot, can't touch for more than five secs. Additionally: TP5/TP6 measure at 16.5V VCASCH is 14.4V VCASCL is -14.4V All three are inline with the published schematic. I'm tempted to just replace all the transistors in the centre current sources, starting with the BC337, as that is where the voltages are incorrect. Grateful for any hints and guidance Thank you.
H&Ks Garf. Last edited by chiily; 1st January 2013 at 05:47 PM. |
#708 |
thats not a big problem, it is the servo compensating the offset of the amplifier. 5V is high but still within the capabilities of the opamp. I would suggest to let it settle another two weeks turned ON and see what happens, eventually this voltage will come down or at least become stable.
#709 | |
). Guys please check the assembly guide, it has my arrangement as an example, worked fine for me and is very low noise. I do use an external pre-regulator (as most of the builders are probably looking at doing anyway). |
#710 |
Thank you for the explanation, anyway it is quite unhappy solution to put elcaps between the cartridge and input of electronic circuits. What is the reason, is there any input bias current flowing into input?? I would always try to avoid elcap coupling capacitors. Sorry to say that but this might be a serious design flaw here and look how the guys complain.
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
