| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#631 | |
Maybe your DMM is plying tricks with you ![]() Please check the rectifiers. A picture of your setup would help enourmously
RC |
#632 |
Hello Rcruz,
I have no second dmm First time I try to get some pictures in here Topside [IMG] [/IMG]Underside, next time I will do better [IMG] DC on output [IMG] DC across the resistor [IMG] AC across the resistor [IMG] AC on output [IMG] Did some mistakes putting pics in, they are in my photo gallery. Regards, Christoph Last edited by brozatus; 27th December 2012 at 11:47 AM. |
#633 |
What are those yellow / black wires coming from the sides of the board ?
What is the AC voltage in the input ? (TX secondaries). Please build a simple diode bridge, connect it to the TX and make the same measurements... (test the diodes continuity befor build just to be sure they are ok) If the diodes are ok, and you still measure AC after the bridge... something is wrong with the DMM
RC Last edited by RCruz; 27th December 2012 at 02:22 PM. |
#634 |
Hello Rcruz,
the yellow and blacks are the cables of the chokes. AC input voltage is 27 v Tomorrow i will try to build the diode bridge and do the measurements. Thanks a lot for helping, Christoph |
#635 |
If AC input is 27Vac, there is no way you could get 80Vac after the rectifiers.... Something must be wrong with the DMM.
Try loading the output of the board with a 1000ohm and measure the voltage across... then lift one leg of the resistor and measure the current throu it with the dmm.
RC |
#636 |
Are you 100% shure, that you got the connection to the trafo right? Are the windings really black/blue each and not black/black , blue/blue (which imho is more common).
Mike |
#637 | |
Mike |
#638 | |
Can you draw/post SCH of your circuit. I wuld reccomend you use 2 rectifiers board to suply Pardise I posted a picture of my BETA PSU the top board uses the same telema common mode cokes Can you etch your own boards as if you need I can post the PCB lay out as I am using it Could you get better diodes? I have posted picture of beta PSU The AC there as shown by your multymeter is definetley wrong Last edited by Bksabath; 27th December 2012 at 05:29 PM. |
#639 |
Sabbath, what transformers did you use?
hoping to pick up some things. |
#640 | |
As you are saying, he has to load output of the power supply board. Plus Vdc vs. ground and Minus Vdc vs. ground with something like 1 kohm - 10 kohm. Without this load, the output capacitors with inductors in series may create resonant circuit and the DMM may either measure voltage on the overcharged capacitor or it is fooled by resonance. With output reasonably loaded, everything should be OK.
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
