Paradise Builders
Paradise Builders
Old 21st December 2012, 02:40 PM   #601
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I use my lab supply too. Plus 12V. I just soldered some thin cables to the battery holder. There is a small hole in the Allas where you can lead the cables out.
Otherwise the batteries are in nirvana in no time.
Old 21st December 2012, 02:43 PM   #602
pdul is offline pdul  Denmark
Another option is rechargeable batteries
Old 21st December 2012, 02:56 PM   #603
Sure.
Old 21st December 2012, 04:07 PM   #604
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Originally Posted by pdul View Post
I use a rarely mentioned invention, called a powersupply for short PSU, to solve that problem.
Or maybe this Multiple-purpose power supply after computer is switched off - US Patent Application 20050050368 Description
Old 21st December 2012, 07:16 PM   #605
deadhead is offline deadhead  United Kingdom
Whilst on the subject of swaps...
In my GB bag i did not receive any 147K resistors but I did get 4x 2k resistors that I don't think are anywhere on the boards. I also received 16x 150k when I only needed 4x.
Did anyone get more 147k than they needed and could they swap with me or if you don't need any swaps could you send me their spare 147's please?
Old 22nd December 2012, 09:10 AM   #606
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise Builders
Ok this is driving me nuts.
Has anyone completed a build using the R3 boards and the group buy parts? Cos all I have is two populated pcb's and not a single damn LED that lights up. Yes all Leds are correct way round and all are working when tested with Atlas DCR.
All 327 and 337 are correctly placed and everything else is in the right place.
Paradise Pre-reg PSU PCBs
Old 22nd December 2012, 09:21 AM   #607
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Hi sq....,
some measuring done ?
Maybe a picture taken ?
preregulatorpeterE-MAIL
Old 22nd December 2012, 09:57 AM   #608
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Yet, something clearly is not in the right place. Check again.
If leds are not alight, your CCS is not working. Correct devices on the sink?
Input power ok?
Old 23rd December 2012, 07:58 AM   #609
Bksabath is offline Bksabath  United Kingdom
Banned
There is no much difference between R3 and R2
Just a couple of footprints for J fets (easier on R3) and the input offset that is now on top of the board
Easy done to place a PNP in place of NPN and to get a capacitor the wrong way around
Did that myself
I wuld triple look at the transistors under the heath sink as well
Old 23rd December 2012, 10:49 AM   #610
Seriously guys, everything is in the right place. All the caps and LED's are the right way round and all the transistors are correctly placed. I've removed the heatsinks and checked everything.
I'll probe some voltages when i get back from my folks after Xmas.
It would be really nice if anyone else from the large group buy could say they had built the psu section on theirs and it worked.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
