| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#492 | |
TP101: 19.93V TP102: 18.23V TP103: 23.83V TP104: 562mV V(in)=29.88V@174mA V(L110): 1.90V V(L111): 1.90V V(L112): 1.91V V(BE Q101): 607mV V(BE Q102): 347mV V(BE Q103): 7.34V V(BE Q104): 1.24V TP201: -19.68V TP202: -18.21V TP203: -23.71V TP204: -571mV V(in)=-29.84V@151mA Last edited by beetle; 11th December 2012 at 10:18 AM. |
#493 |
The resistors wont be changed,
is there a known issue ? |
#494 |
A picture tells more than a thousand words, so here is a picture.
The voltage (Vgs) of the mosfet is about 4V, the current that is (selected by me) wanted in the Jfet is 1mA. The picture shows resistor values for popular Jfet's to accomplice this (1mA). What can be seen is that, in fact, the J310 is the most marginal of the shown Jfet's (it is just capable of supplying the wanted 1mA). Any of the Jfet's shown can be used (and I am sure there are many more) but you need to change the resistor value and indicated.
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
#495 |
Ive asked this rather stupid question because in the GB mine,
and many other sets delivered, contained only the alternative fets.... |
#496 | |
#497 |
I am new to transistor matching so the question might be silly, but would a device such as the following be useful?
Found at Reichelt: ATLAS DCA55 Your feedback will be appreciated - thx. dubai2000 |
#498 | |
In fact, matchign the gain devices makes a hell of a difference for audio amplifiers, as compared to just sticking in whatever comes out of the bag first. Many higher-performance (non-feedback) circuits really only work with selected / matched devices. |
#499 |
I use it all the time. Buy it.
#500 |
diyAudio Chief Moderator
Watch only that the Atlas does shove much Ib with a CCS inside, so the reported Vbe will be more than usual in circuit. But if they match @ that condition they do follow with other bias states more or less. Good thing is it tests LEDS in a much more real life 3.5mA than the proverbial 1mA that meters do. Many don't even put out enough voltage to light an LED to start with. What Vf matches on my Atlas matches on my F87V too, but when looking to use them as voltage ref you need to know not only matching but Vf @ bias current too. Ah, and Atlas is a battery hog.
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
