Paradise Builders - Page 5 - diyAudio
Old 23rd October 2012, 01:58 PM   #41
Benedetto's Avatar
After measuring the Transistor ive got from Frans
i got
HFE BC337-40 BC327-40
420...............3x.............................. ......1x
430...............7x.............................. ......2x
440...............8x.............................. ......4x
450..............10x.............................. ......9x
460..............11x.............................. ....15x
470................8x............................. ......30x !
480................9x............................. ......27x !
490..............10x.............................. ....10x
500................3x
510...............13x
520...............12x
530................4x
257............................................... .......1x
289................1x
Measured on duewi DMT7977
The question now is witch to drop where ?
preregulatorpeterE-MAIL
Old 23rd October 2012, 03:11 PM   #42
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by pdul View Post
Has anyone found a good technique to keep the insulationpads in place while mounting the powertrannies, without the screws to help?
If you use mica insulators is easier.
Once the power trannies are in place, lift the spring and pull them in with your fingers
RC
Old 23rd October 2012, 03:15 PM   #43
pdul is offline pdul  Denmark
I wonder if its possiple to buy the siliconepad as a sheet, so i can put one piece to cover the whole surface?
Old 23rd October 2012, 03:25 PM   #44
Kerafoll 86/83
Where do you buy this?
Old 23rd October 2012, 03:47 PM   #45
i got
Maybe it would be a good idea to start a transistor trading thread.
I have already traded some with Joachim with great result, got a lot of good pairs out of it.
Old 23rd October 2012, 03:58 PM   #46
Benedetto's Avatar
If one fine day the GB-parts arrive
who knows what value those trannies got...
Old 23rd October 2012, 04:28 PM   #47
you already have 8 nice pairs at hfe490 for the inputs of both boards.
Old 23rd October 2012, 04:31 PM   #48
Then look at the assemply guide in post 13 to place the rest. Hesener has a very good explanation there about the ishue.
Old 23rd October 2012, 04:43 PM   #49
Banned
Kerafol 86/83 in my case
Yes I did cut a strip of a load I got. No problem realy fitting it tiny tiny litle bit of therm grease just to stick them there.
One can first Fit midle transistor on sink set to board, place second transistor hold in place take lot out, clamp repeat for 3, .... once al done Just weld in place altrought the welding part has been frown upon a while ago If you find that you will also find picture of clamping device
In which case line up transistors on board, solder then fit sink and clamp even 4 years old can do that
Clamping device I can sell you for 42 or you can look at picture and buy one for 3.50
Got **** load from Keratherm minimum order qty aplies got 550 X350 mm sheet. do not bother with cut shapes as they charge (rape) for tooling as well
I cut strips of 19 mm so can do TO3P TO247 and TO220 by changing orientation of pack.
By the way before you do all this the TO3 close to sink need to go in and have shorth legs or they touch the sink
Old 23rd October 2012, 04:46 PM   #50
Banned
Fine by me but Hi Hfe especialy there on inputs is beterer.
I do not have mine so far but I got a stash from Fairchild and Hfe was sky hi on those.
So question: how do you measure them?
Distribution of Hfe values in theory shuld be a bell shape shape on graph paper where midle ground Hfe got more transistors but this if one get full batch
Paradise phono stage hesener Group Buys 1375 19th September 2016 02:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright 1999-2017 diyAudio
