Paradise Builders
Paradise Builders
Old 7th December 2012, 10:00 PM   #461
beetle is offline beetle  Germany
I might have some of them in stock. Will have a look. Thanks!
Old 7th December 2012, 10:00 PM   #462
pdul is offline pdul  Denmark
Pardon me for asking.
Is the schematics and layout available for us who were too late in here to buy when the groupbuy was open?
Why not start with Tandberg
Old 7th December 2012, 10:28 PM   #463
MJE15030/31 also good?
Old 7th December 2012, 10:58 PM   #464
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by beetle View Post
Thank you! I Just quadruple checked the components. Stuffing looks fine. Annoying. Group buy came with D45H11 PNP tranies instead of TIP32C. Will obtain TIP32 transistors from reichelt and try again.
They are the same do not worry about those. I had the same with R2 Beta build
Old 7th December 2012, 11:06 PM   #465
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Sure,
everything should been found there
Paradise phono stage
preregulatorpeterE-MAIL
Old 8th December 2012, 06:31 AM   #466
Perfect
Old 8th December 2012, 08:03 AM   #467
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise Builders
Marra, no they'll do a handfull. I bought tens of everything just in case. Select the best match grade, I got 'F'. 1%
I have plenty of 33n and 11n if you'd like some, drop me your address I'll match you some up, then you just need to fine tune with a couple of hundred pf.
Paradise Pre-reg PSU PCBs
Old 8th December 2012, 08:57 AM   #468
Banned
Can I have 2 sets please
Old 8th December 2012, 10:12 AM   #469
With MJE15031 I(in) is now 172mA pos rails and 150mA neg rails.
Old 8th December 2012, 10:55 AM   #470
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Show me (one more time) a full set of voltages test-points, Vin and Vout. Also would you measure all Vak(LED's) in the CVS and the CCS and, V(be) power and small signal transistors. It seems that the PSU is working but I want to know (at a philosophical level) why it is (as it is). This will make it easier to help other people.
P.s. The MJE's should be good, also the TIP's and the D44/D45's, but the D44/D45 where my first choice
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
