Paradise Builders
Paradise Builders
Old 6th December 2012, 09:52 AM   #441
herrstagl is offline herrstagl  Austria
Default RIAA Caps
I am somewhat confused about the RIAA Caps. The manual states 1 x 33.3nf and 1 x 11nf. However, there is another thread about V-Caps, where 1 x 32nf is going to be used instead of the 33.3nf.
Thel offers KP Caps with 33nf.
My question now is: Shall I go for FKP2 with exactly 33.3nf or shall I go for the 33nf?
Many thanks, tom
Old 6th December 2012, 09:56 AM   #442
pdul is offline pdul  Denmark
You can combine the caps to get as close as possible, to 33,3nf
Old 6th December 2012, 10:13 AM   #443
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
33,3 / 11 nF are the official values. As Stefanoo knows better (as usual ), you might want to try his 32 nF option. There's even a third combination floating around somewhere (from RCruz, me thinks).
33,3 nF is best done with 10nF || 10nF || 10 nF || 3.3nF, 11nf is 10nF || 1nF.
Best regards: Holger
www.holgerbarske.com
Old 6th December 2012, 10:24 AM   #444
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Ricardos version is totally flat whereas the numbers that MiiB and i came up with have a little lift of 0.5dB towards the deep bass, the so called house curve.
That curve makes sure that the Paradise never sounds too sharp. We found that use full because not all records are perfect. The difference it makes is rather small though.
Old 6th December 2012, 10:42 AM   #445
Gents,
thanks for your response. I feel very safe with your values. So I go with 33.3nf and 11nf.
I just talked to Oppermann regarding Styroflex MESK25 Caps with 0.5%. They have following values:
1) 27700 + 5690 = 33390
2) 10000 + 1000(only available in 2%) = 11000
Three questions:
1) The values are not exact. What would you recommend. a) go for exact values and use FKP2 b) go for these values
2) They are really big. Has someone tried them
3) If they are an option, does someone else like to have some?
thanks, tom
Old 6th December 2012, 10:48 AM   #446
Giving away the best part sources, you... .
Those caps are big, won't fit the board without problems.
Even if your values aren't perfect, I'd go for those nice KP babies.
Old 6th December 2012, 10:59 AM   #447
buzzforb is offline buzzforb  United States
buzzforb's Avatar
...Shape the sound , Man!
Old 6th December 2012, 01:48 PM   #448
Bksabath is offline Bksabath  United Kingdom
Banned
33,3 / 11 nF are the official values. There's even a third combination floating around somewhere (from RCruz, me thinks).
No big fuss about RIAA small difference, as long as it comon on both channels
Riccardo combination (which I trust ) may be a better one,and shows in which direction to compromise when sorting the caps out
Old 6th December 2012, 02:31 PM   #449
Doppelkopf is offline Doppelkopf  Germany
Hello .
I have matched the BCs and got a set BC327 nice around 400 hFE and one around 500 hFE.
From the BC 337 ive got a Set around 500 hFE .
What is to do ; using thr 500 wiht the risk of ozillation , or buy / swap some BC337 with lower hFE ( around 400 ) with someone here ?
Whats best ?
greatings , Dirk
Old 6th December 2012, 04:22 PM   #450
Banned
It is all depending on your skill set, how much work you are villing to put on it and the lab set up you got.
400 Hfe is best safe options at least for current mirrors but input benefit from hi Hfe as far as I understand
I will need to vear same artic gear to work in my loft (around 7 C at the momement) and get same set matched up so if you got time I am willing to help but maybe finding some body near you may be best option
Did I say this before?
PS some how with poorly matched set at around 540 I got no oscillation on R2 so ....
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 01:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
