| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#31 |
I think its 1.8v across each led with the long lead going to the markings on the circle on the pcb.I'm sure someone will correct me if I am wrong.
#32 |
I used green 3mm leds
#33 |
It pays to use brand leds. Some of those from fleabay have a very short lifespan.
#34 |
At least this much is crystal clear.
But i do foggy recall there was a value for every chain. Sorry for picking... |
#35 |
Bought mine from world famous Buerklin.
#36 |
Well.... use only "normal" brightness leds because each one should drop around 1.8 ~ 1.9v.
Be carefull to place them correctly (one inverted led will prevent normal functioning) The marking in the board indicates Anode (+) Long leg. You can use low current leds. IMO Lowest noise comes from yellow ones but red are also ok
RC |
#37 | |
#38 |
Has anyone found a good technique to keep the insulationpads in place while mounting the powertrannies, without the screws to help?
#39 |
What kind of pads do you use ?
#40 |
Just tiny litle bit of heat transfer not needed with Kerafoll but one only has 2 hands.
Kerafoll 86/83 |
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
