Paradise Builders
Paradise Builders
Old 3rd December 2012, 07:57 AM   #371
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Originally Posted by beetle View Post
Uled=1.918V
Ur102=3.448V
That is 1.9 + 3.4 = 5.3V the expected voltage here is V(L111) + V(L112) - Vbe(Q104) and that is 1.9 + 1.9 - 0.6 = 3.2V. It is actualy 2.1V to high, check the led voltages L111 and L112 and replace them if needed. Replace Q4 and posibly replace Q103.
There is one thing that I do not understand, V(L110) = 1.918V so V(R104) should be 1.9 - 0.6 = 1.3V and I(R104) should be 1.3 / 10 = 130mA and that should not depend on V(TP103), mmm... anyone else?
Old 3rd December 2012, 08:22 AM   #372
hesener is offline hesener  Germany
Paradise Builders
Originally Posted by FdW View Post
I'm not sure where you did measure these, can give your voltages as indicated in the attached PDF? The total wattage from the raw-PSU is being disipated in the regulator (about 120mA @ 24V = 30 Watt (more or less)), if the RIAA is not connected it will get very hot. Check the voltage across the two 10 Ohm (R140/204) resistors, it should be 1.2V.
oops... 120mA @ 24V is 2.88W....
With an input voltage of 30V, and output voltage of 18V, power dissipation in the shunt is 2 x 12V x 120mA = 2.9W, that should be no problem for the heatsink. (that was also the design target).
If the outputs are shorted, all power dissipation goes into the current source transistors, but it will be the same power dissipation. If the outputs are open, the power dissipation goes into all power transistors, still teh same total power. If the amplifier is connected and draws power, the power dissipation in the regulator is reduced accordingly and the temperature should be lower than in the other two cases.
So it should be quite foolproof, unless the stuffing devil has hit you....
Old 3rd December 2012, 08:41 AM   #373
FdW's Avatar
Paradise Builders
Ooops one zero too many, sorry for that.
Also: If the RIAA is not connected, then all (potential output) power is consumed by the shunt.
And, yes, it should be 'quite foolproof'
Old 3rd December 2012, 08:50 AM   #374
Paradise Builders
[QUOTE=FdW;3268178
And, yes, it should be 'quite foolproof' [/QUOTE]
That's what we expect from you, and how the shunt actually behaves in reality ;-) I am still considering doing a separate PCB for it (if you don't mind of course) because it can be used in many different applications, due to its very good quality
Old 3rd December 2012, 08:57 AM   #375
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
I agree. Very nice shunt. Already planning to cut off the shunt part of the pcb if nothing comes out of the riaa.
Old 3rd December 2012, 09:32 AM   #376
FdW's Avatar
Paradise Builders
Thanks Yes it is a good idea to make a board for it, the number of LED's in the LED-string should be something line 20 for up to 42Volts output. The CroMagnon is, for instance, running at 35Volt and needs 17 LED's in the string.
Old 3rd December 2012, 11:43 AM   #377
analog_sa's Avatar
Here is a picture of the output with a 1k cart loading resistor at input. Approx 7-8mV @8MHz (ignore displayed vertical scale).
When the input is loaded with 47ohm oscillating frequency stays the same but amplitude triples.
So far i have not played with PS decoupling of the input stage or mirrors as presumably the layout works with the particular combination of parts some builders have already tried. Why it doesn't work with what i got from the group buy is indeed a mystery.
Has anyone successfully built a Paradise using the GB parts?
Old 3rd December 2012, 12:07 PM   #378
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Is it possible that the parts are the issue as i have seen some discussion in that GB thread as to the legitimacy of some components?
...Shape the sound , Man!
Old 3rd December 2012, 12:21 PM   #379
analog_sa's Avatar
I am aware of the discussion - it seems to be based on the general discontent of one contributor, rather than any solid fact.
The problem most probably has to do with the particular batches of transistors, or maybe only the Hfe. Hopefully someone will come up with a solution. Shame about the pretty boards, at least those seem to withstand quite a lot of abuse...
Wasn't the initial version scrapped because of oscillations blamed on the output bipolar buffer and hence the fet update? Looks like it wasn't the buffer.
Old 3rd December 2012, 12:48 PM   #380
Paradise Builders
In R1 it was pretty much the entire board oscillating, I was trying to implement a fancty-pantsy-ground layout which basically didnt work. The R2 and R3 (which you have) now have:
1. one BIG ground plane with short connnections
2. SMD footprints on the bottom side of the PCB, right at the mirrors, for local decoupling
3. Much simpler (voltage follower) output stage, which is significantly less prone to oscillation than the R1 output stage
My experience seemed to indicate that high HFE will increase the tendency to oscillate. FWIW, I had transistors at around 400 for NPN and PNP, worked beautifully. My recommendation would be to put 400's in the input stage, and use the decoupling caps in both mirrors (100...1000nF X7R ceramic caps, size 1206 or 1210).
Keep posting if the problem goes away!
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 20th May 2018 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
