Paradise Builders
Paradise Builders
Old 13th March 2014, 11:07 PM   #3391
Howlindawg is offline Howlindawg  Ireland
Howlindawg's Avatar
Originally Posted by miepa View Post
https://docs.google.com/document/d/1...-tE/edit?pli=1
look at hesener`s documents - its all in there!
I guess I'm missing it Michael.
I saw the section in the docs on how to disable the onboard buffer but not a section that outlines the components that are redundant when using the Calvin buffer. I'll keep looking.
Old 15th March 2014, 09:15 AM   #3392
Calvin is online now Calvin  Germany
Calvin's Avatar
You can omit with all original buffer parts, i.e. Q90/91/92/99 and the associated resistors R12/13/15.
You may insert the Calvin Buffer instead, with the exception of the 100k Input resistor R15.
R15 may only be needed if the Calvin Buffer is used as standalone subassembly.
You also would need to change a couple of resistors in the power supply to deal with the increased current demand.
jauu
Calvin
Old 15th March 2014, 11:34 AM   #3393
shoom is offline shoom  Europe
Hi Howlingdawg
i used the 7.5ohm Value CCS resistor suggested by Frans which works well in my set up.
''About the Paradise PSU when using Calvin buffers
When using Calvin buffers in combination with the Paradise RIAA the preamp is going to need a bit more power than originally planned. The Paradise RIAA needs about 80mA and the Calvin buffer needs an additional 30mA.
For the shunt to function it needs to consume a few mA’s (30mA is the design value, actual values from 25 up to 50mA are acceptable). This results in 30ma x 18V = 540mW and 110mA x 8V = 880mW constant power consumption in the voltage regulator (Shunt, CVS and CCS), the total power supply consumption is:
2 x ((30mA 18V) + (110mA 8V (26Vin – 18Vout))) = 2.8Watt
When connecting the Calvin buffer an additional 30mA needs to be supplied, the CCS setting needs to be changed from 110mA to 140mA, this can be done by changing the 10 Ohm resistors to 7.5 Ohm resistors. See the attached JPG (The attached screen shows the CCS current in the PSU for (E24) resistors from 4.7 to 10 Ohm (currents from 240…105mA (give or take a few mA’s)).
The ‘normal’ power supply dissipation now changes to:
2 x ((30mA 18V) + (140mA 8V (26Vin – 18Vout))) = 3.4Watt
This should not be a problem with the supplied heat sink, but care should be taken to ventilate the area surrounding the PSU heat sink.
When testing the PSU (with the RIAA and buffer disconnected) the total power consumption in the PSU will be 140mA x 26V = 7.3Watt. If the PSU is not placed in a closed box this should not be a problem, the heat sink may get hot (up to 70C or so) and should not be touched (but you will know (as a regular soldering iron user)).
As ever, be sure that the final enclosure is well ventilated (especially around the PSU).
Frans''.
hope that helps
Old 15th March 2014, 12:35 PM   #3394
RollE2k is offline RollE2k  Sweden
Myself i use 9.0ohm CCS resistor and i do have 138-139mA total current - which in my case should be enough, 80mA + 27mA (Paradise+Calvin) which is 107mA total current. So i have approx 30-33mA shunt current. It should probably be closer to 40mA since the old output stage is removed (was around 6mA i think).
I don't have the largest case for my boards, so i try to get minimum heat needed.
Old 15th March 2014, 03:19 PM   #3395
Howlindawg's Avatar
Fantastic, that's very helpful.
Thanks all!
Old 23rd March 2014, 11:58 AM   #3396
Abraxas336 is offline Abraxas336  Europe
Abraxas336's Avatar
Hello,
today I finally got around to install my Calvin buffers. I have two cases of "Shunt regulator LEDs do not light up – check for short circuits on the buffer or the connection"
Lights come up when I remove the buffers so it has to be on the buffers themselves (on both of them). I can't find any obvious shorts though. Any typical mistakes that lead to that error?
Many Thanks
Sven
Gruenschnabel
Old 23rd March 2014, 05:58 PM   #3397
Sven: I had the same problem on one channel - and for me it was the sinked transistor where the short was. So start checking there!
Old 23rd March 2014, 06:01 PM   #3398
''When connecting the Calvin buffer an additional 30mA needs to be supplied, the CCS setting needs to be changed from 110mA to 140mA, this can be done by changing the 10 Ohm resistors to 7.5 Ohm resistors. See the attached JPG (The attached screen shows the CCS current in the PSU for (E24) resistors from 4.7 to 10 Ohm (currents from 240…105mA (give or take a few mA’s)).
As ever, be sure that the final enclosure is well ventilated (especially around the PSU).''
Hi Sven
have you changed the 10ohm resitor? you may not be pulling enough current through the shunt.
and
did you build the Buffers to the updated boom? also did you leave out the 100K R15?
just wild guess work but.
Old 23rd March 2014, 06:16 PM   #3399
Abraxas336's Avatar
Yes I did leave out R15 and I followed the few changes on the last page of the assembly guide. I don't have any visible shorts, I'm sure.
How about the pin layout of the output transistors - it seems the 2SA1381 is not different from the Fairchild BD14016STU I used. I assume the side with the writing faces up?
Beside the BD140 I used Fairchild J107 and PF5102 so the whole pin layout stuff should not be a problem?
Gruenschnabel
Old 23rd March 2014, 06:24 PM   #3400
For me the 2SA1381 was kinda "short-legged" so i isolated the legs with teflon tubing - since they pretty much touched the sinks. Even though somewhere there it became a short - until i moved them a little bit closer to the solder-pads. Then the problem went away. So i would start checking there.
Also, check that the J-fets are in the right direction.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
