Paradise Builders
Paradise Builders
Old 2nd December 2012, 03:45 PM   #331
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
I am inclined to think the reason for the positive bias is a disbalance from the transconductance stage which the servo fails to fully correct. With the servo switched off there is a positive 1 - 3v appearing at the output of the transconductance stage. No idea why as my bipolars are carefully selected. Maybe i have made a mistake somewhere...
Old 2nd December 2012, 03:59 PM   #332
pdul is offline pdul  Denmark
It sounds exactly like the problem i have too. the wandering offset on output, and riaa, but input and psu is ok. Finally someone else have the same problem
Old 2nd December 2012, 04:06 PM   #333
Could it be the fets playing tricks?
Old 2nd December 2012, 04:08 PM   #334
My problem is the same in both channels
Old 2nd December 2012, 04:13 PM   #335
analog_sa's Avatar
Fixed the issue with the insufficient voltage across the output 2SK170. Indeed Joachim was correct - top FET needed replacement.
As for the randomly moving dc levels i still have no idea. And it is very consistent between channels.
Old 2nd December 2012, 04:14 PM   #336
analog_sa's Avatar
Which fets would those be? The problem exists ahead of the output buffer... and is not related to the servo.
Old 2nd December 2012, 04:23 PM   #337
What else? The bipolars are well matched
Old 2nd December 2012, 04:40 PM   #338
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I had initially an offset of around 25 to 40mV. That went down after a while. I assume that is forming of the electrolytics in the input stage ( 2 x 6800uF ). They have some leakage current that goes down with time in use.
If after several days in use the DC offset at the output does not go down there are instructions in the building manual how to raise the "authority" of the servo.
Yes, i ment searching for J310 that leave enough Vds ( Uds ) over the 2SK170.
Old 2nd December 2012, 04:44 PM   #339
There is also a little discussion on the other Paradise thread if the OP134 in the group buy are fakes. No conclusion yet but if that is the case then the servo opamps have to be substituted with a genuine one.
Old 2nd December 2012, 04:47 PM   #340
It is not the stable offset from the buffer, that is the problem, it is the wandering offset at the riaa note +/-100mv. Jumps around constantly as if it were sampling a bigger curve.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 20th May 2018 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
