Paradise Builders
Paradise Builders
Old 1st December 2012, 11:23 PM   #321
beetle is offline beetle  Germany
Found it. Wrong cap. Will fix it tomorrow.
Old 2nd December 2012, 12:40 AM   #322
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I can read brain waves C:
I fact it is always the same sh.....
Old 2nd December 2012, 11:59 AM   #323
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
Paradise Builders
Originally Posted by Bksabath View Post
I got pupu load of 327 (FEW UNDREDS) with HFE above 540 and few undreds 337 with with HFE around the 500 mark
PM on its way.
Old 2nd December 2012, 12:40 PM   #324
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
That's easy done!
Old 2nd December 2012, 01:17 PM   #325
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
For some reason the SK170 in my output buffer fails to properly bias - gate stays positive and output offset fluctuates randomly within a hundred or so mV. Have not yet hooked a scope. Apart from that all other dc levels read fine.
Scratching my head...
Old 2nd December 2012, 02:53 PM   #326
What DC voltage do you measure between drain and source of the 2SK170 ?
Old 2nd December 2012, 03:00 PM   #327
analog_sa's Avatar
1v in one channel and 2.3v in the other. Vgs is slightly positive in the first channel
Old 2nd December 2012, 03:06 PM   #328
Then the J310 cascode Fet does not provide enough voltage over the 2SK170.
When the Vds voltgae over the 2SK170 falls under a certain threshold there is not enough Vgs left to make the 2SK170 conduct negative.
Search for the highest voltage J310 you can find and use them as the cascode transistors over the 2SK170. This is simply bad luck.
Old 2nd December 2012, 03:08 PM   #329
analog_sa's Avatar
Highest voltage?
Old 2nd December 2012, 03:12 PM   #330
analog_sa's Avatar
I also experimented a bit without the servo or the output buffer. Quite serious random DC fluctuations at the transconductance riaa node. The servo manages to calm these down but because of the integration there is still up to a 100mV dc at output at times even with the servo on. Could this possibly be normal?
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
