| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#311 |
Take a look at the assembly guide, at the end I documented my approach to shielding and grounding, worked beautifully for me. Yes the Paradise is dead quiet if done right.....
#312 |
Here is good stuff :Technics | Cartridge Data | Vinyl Engine
you should be able to shoot one for 50 to 100$ |
#313 |
Thanx to both of you !
Im quite confused a bit because on MDR runs the legendary Isle of Wight Hendix gig........ C ya tomorrow. |
#314 |
Guys I'd appreciate some input here.
I have measured all my 327's and 90% of them are sub 300hfe, I have 50 ranging from 375-420 but nothing above this. But 99% of my 337's are 500+ (500-540 mostly) and I have maybe 5 that measure between 450 and 500, but none below 450 So I can't match ****. Does anyone have a suggestion for a vendor of better 327's and suitable grades? All help greatly appreciated.
hoping to pick up some things. |
#315 |
Carolus has same but opposite problem in the other Paradise tread
Paradise phono stage part GB post 216 Dig it up and and option 1 make swap with him option 2 I got pupu load of 327 (FEW UNDREDS) with HFE above 540 and few undreds 337 with with HFE around the 500 mark I be happy to help PM on its way Last edited by Bksabath; 1st December 2012 at 10:45 PM. |
#316 |
How hot should the headsink become? Mine is getting boiling hot. Can't leave my fingers on it for more then a second. Output voltages are ok. Input voltage 30V@206mA positive and 30V/152mA negative rail.
#317 |
Boiling hot is not right. Input conditions are ok so it does not come from over voltage .
Frans, do you have an idea on what to check ? Un symmetric current draw is a bit strange too. Reversed electrolytic ? Can you look if one on the electrolytic capacitors shows an expanded top ? There are slots in the cap that break when an elcap is reversed. |
#318 |
They all look fine. And soldered in correctly.
#319 | |
any way for you to mesure? Running hot on my R2 mesured 48 C with extra sinks and 68 C with sink suplied for R2 see My paradise tread post 18 and after MY PARADISE Ideal voltagge shuld be about 26 V 150 mA sound about right 200 mA on other rail is to much Provided there is nothing wrong with components (but that 200 mA look a bit suspicious) option 1 change trafos for 18 18 V ac ones (just got 2 of those to fit next week if you can wait I will report about it) option 2 add further CRC after rectifiers (I got 4400 uF 10 Homs 4400 uf fitted inside phono box) IMO to go a bit hi in voltage and use same extra CRC is way to go Last edited by Bksabath; 1st December 2012 at 11:12 PM. |
#320 | |
Switch off for a while (sleep over it) and start afresh. Cek each single capacitor on the board. |
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
