Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#301 |
Banned
Fair points and intelligent question
As far as I understand the imputs benefit from hi Hfe No so much for the current mirrors Like you for same guide lines would be most welcome On shielding I am currently using a 304 stainless stell box (non magnetic) and the boards are mounted inside a open top second box made with cooper Noise is just not there but this IMO is in grand part due to the clever design and board quality. |
#302 |
Did see your nice build.
But for discussing proper shielding, only the audible abscence of noise is not really a fact. |
#303 |
Banned
Tanks that is just beta....
Much smaller surface area for R3 it is a fact that with amp at max and ear glued to speakers I can not ear any noise when needle is up also a fact that I am not realy bothered by frequency above audible low band with of ears and twetters take care of that. I say buid Paradise to start with and then if you decide that improvment is needed no body is going to stop you to build new box Propper shielding may involve Mu metal multiple layers as they do on moving coils transformers this can be had as A4 paper thin sheet from E bay or one can use EMC shielding Paint on multiple layer paper sheet all good stuff as long as one get to play a few track in between builds. |
#304 | |
nhinstruments
RC |
#305 |
A Hfe of 400 is enough, IN ALL POSITIONS.
#306 |
And yes, the Paradise is dead quiet, when shielding, grounding and boxing is done right.
Short circuiting the input makes the noise even lower. The cartridge has some Johnson noise too. Your DL103 with 40 Ohm is 4 times more noisy then the Paradise itself, Benedetto. |
#307 |
Banned
I keep those in the MY Paradise tread http://www.diyaudio.com/forums/analo...-paradise.html
#308 | |
my most beloved one o three is worn out ! ![]() Donno where to go or what to do..... |
#309 |
Buy a used Pannasonic from the 70th, they are really good.
#310 | |
Thread | Thread Starter | Forum | Replies | Last Post |
Paradise phono stage | hesener | Group Buys | 1376 | 12th August 2017 01:27 PM |
DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
New To Site? | Need Help? |
