Paradise Builders
Paradise Builders
Old 16th October 2013, 04:13 PM   #2951
hesener is offline hesener  Germany
Paradise Builders
Check this out, Audio input selector switches
Have not seen a 12-position switch but you can always ask them...
Paradise documents are here: Link list
Old 16th October 2013, 04:38 PM   #2952
Bksabath is offline Bksabath  United Kingdom
Banned
But why not DIP switches and the advantagge of multiple Parallel combinations ?
Old 16th October 2013, 04:46 PM   #2953
RollE2k is offline RollE2k  Sweden
DACT are really expensive, and uses elma parts for many of their switches - which is why i looked at ELMA.
DIP would work - but it sounds better not to have parallel, plus i already have my case-front-panel drilled for a rotary at the front - so too late for that now.
Anything between 8 - 12 position would work - i just want to squeeze in a few more loading values.
Old 16th October 2013, 07:27 PM   #2954
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Originally Posted by FdW View Post
Sorry Ricardo, these are not 'my' threads. Only the thread 'owner' can amend the first post (and the site admin(s) and moderator(s) ).
P.s. Edit: And the NSA
P.p.s. Edit: And the ATL guys
So maybe Joachim can help....
RC
Old 16th October 2013, 07:31 PM   #2955
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
What exactly is my duty ?
Old 16th October 2013, 07:50 PM   #2956
nhinstruments
RCruz's Avatar
Paradise Builders
Please add a link to FdW post in your first post of this thread....
RC
Old 19th October 2013, 12:06 PM   #2957
By the way - i found that Goldpoint does have switches custom made, so i could have the switch i wanted - unfortunately they wanted $117 + $40 shipping, and then vat+customs, so it would end above $200 which is way to much for me. so i'll probably just use the elma switch for $60 instead, until a cheaper alternative turns out.
Old 19th October 2013, 12:19 PM   #2958
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
You must dislike relays a lot.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 19th October 2013, 01:15 PM   #2959
Paradise Builders
In my new build (using tubes - don'T tell joachim ) I am using C&K driving relais (takamisawa), works well
Old 19th October 2013, 02:11 PM   #2960
Normally i don't mind relays, especially latching ones. But for cartridge input i would perfer a switch.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 01:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
