Paradise Builders - Page 294 - diyAudio
Old 14th October 2013, 11:01 AM   #2931
hesener is online now hesener  Germany
Originally Posted by Calvin View Post
Hesener, have a look at my preamp buffer thread #171 and 172
jauu
Calvin
yes, that is a great circuit. I have seen it already but forgot... sorry! now if only we could get rid of that coupling cap...
Paradise documents are here: Link list
Old 15th October 2013, 10:30 AM   #2932
Send a message via MSN to sq225917 Send a message via Skype™ to sq225917
Just a quicky, is there any preferred value for 'idss' for the 2sk170 parts? The higehr the better?
Paradise Pre-reg PSU PCBs
Old 15th October 2013, 10:48 AM   #2933
Each circuit tends to perform optimally with a much narrower range of Idss than is available in the full gr to v.
Even the typical bl range is overly wide to simply pick out at random.
Some circuits will prefer a low bl, others a medium bl and some a high bl.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th October 2013, 11:39 AM   #2934
nr12 is offline nr12  Germany
Look here:
Paradise Builders
Old 15th October 2013, 11:50 AM   #2935
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Que ?
Paradise Builders
President Dwayne Camacho says you should drink Brawndo : It's got electrolytes
Old 15th October 2013, 12:05 PM   #2936
Hmm, whats the difference?
different links, both point to the same post..
There was something about posts per page and links to older posts, or?
Old 15th October 2013, 12:11 PM   #2937
I was actually asking about the ones not in the shunt. I use J113 in that location.
Old 15th October 2013, 12:17 PM   #2938
Only for you, not for others.
Old 15th October 2013, 12:41 PM   #2939
Here is the explanation for the link problem (hopefully with a correct link...):
Links to posts depend on "correct" #posts per page to work
Old 16th October 2013, 07:07 AM   #2940
Banned
You mean Frans Graphs whit different Jfets ?and resistor values
Where is is now?
Tanks Frans
(I am sure he is going to post it again)
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright ©1999-2017 diyAudio
