Paradise Builders - Page 287 - diyAudio
Old 19th September 2013, 08:33 PM   #2861
Marra is offline Marra  United Kingdom
Since casing up my Paradise build it has never been fully hum free but this has been made noticeably more prominent since installing a recently built Aleph J into the system.When music is playing I don't notice the hum but can hear it from my listen position between tracks.It makes no difference if the earth wire from the deck is connected or not.The only thing that stops it is gripping the right output phono plug between my thumb and finger.
Any advice gratefully received.
Old 19th September 2013, 08:53 PM   #2862
Benedetto's Avatar
HI M,
what grounding schema did you apply ?
preregulatorpeterE-MAIL
Old 20th September 2013, 09:43 AM   #2863
Originally Posted by Benedetto View Post
HI M,
Hi B;I had hoped to post pics but my camera won't charge for some reason.
In the p/s box the mains earth is connected to the chassis and a wire taken from this point to a 7 pin connector and through to the Paradise box where it is connected to the chassis.The +G- wires times 2 connect to the two Paradis pcb's. Grounding in the phono amp consist of a wire from each boards output to the chassis ground along with the deck grounding post which is connected to this point through a resistor/capacitor isolator.
Having relooked at Frans schematics and BK's posts I think? that I have misinterpreted them
Old 20th September 2013, 09:50 AM   #2864
hesener is offline hesener  Germany
Thats ok, these wires should connect at the power connector (upper righthand corner, next to the heatsink). If all else fails (see below) you may want to put two power diodes (back to back) between the mains earth and the P/S ground, nelson pass style....
IMHO the grounding in the phono amp should consist of two wires coming from the INPUT connection on the PCB (can use the second pair of input pads for that) to te grounding post, and there should be no resistor/capacitor isolator there. Rather, connect the p/s ground to that post as well, making it your star ground connection.
Let us know if that works, thanks
Paradise documents are here: Link list
Old 20th September 2013, 10:54 AM   #2865
Thank you Alfred I will try your suggestions over the weekend.
Old 20th September 2013, 07:36 PM   #2866
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Marra.... simple but effective... do not connect circuit minus to mains earth... leave it floating.... that will cure any hum.
Connect TT arm ground to circuit (minus) (as long as TT arm gnd is not connected to mains earth.
Mains earth should be used only for security reasons and only in the psu case and using two parallel inverted diodes.
Amplifier case should be connected to circuit minus and disconnected from mains eart.
RC
Old 20th September 2013, 08:22 PM   #2867
Ricardo, with all due respect, but I tend to disagree, for the reason you cite - security. I think you are setting yourself up for a dangerous electrical accident if you have no connection to mains earth, in your entire system. (And I don't think it is a cure-all for hum problems, either).
I know that many systems do without ground, some have "accidental" grounding through one of the components of the system, etc etc - all examples for not-so-great grounding schemes, in my opinion, apart from the apparent lack of security.
One very effective way is, as you mention, the back-to-back diodes between mains-earth and system ground. And,, these should not be 1N4004's, but big, robust power diodes e.g. RURG80100 or similar, so beefy that they will survive the accident and cause fuses to blow, not the diodes.
Old 20th September 2013, 08:33 PM   #2868
nhinstruments
RCruz's Avatar
That is what I meant... maybe I did not explain very well.... The PSU must be connected to mains earth using two diodes back to back, but the amplifier case can be left floating as the voltages there are not lethal.
TT ground should go to the amplifier case and circuit minus, and should be isolated in regards to mains earth to avoid ground loops.
Me and FdW did a good study about that and posted a good solution.
RC
Old 21st September 2013, 05:30 AM   #2869
nhinstruments
RCruz's Avatar
In this case circuit minus is in reality circuit ground, not the negative rail obviously
And this is not a cure for all... one should also look for other potential loops in the system.
RC
Old 24th September 2013, 10:02 PM   #2870
miepa is offline miepa  Austria
any pics of boards which used the V-Caps in the RIAA?
just wondering how you guys installed them on the board.
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright 1999-2017 diyAudio
