Paradise Builders
Paradise Builders
Old 29th August 2013, 06:29 PM   #2721
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Voltage in the base of Q104 (first BC337 on the positive ccs) is 16.6v and should be 22v
Voltage in the 10 ohm resistor is 14.8v and should be 19.4.
RC
Old 29th August 2013, 08:36 PM   #2722
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
What is the output voltage if you disconnect the led-chain (just remove the adjustment resistor).?
After a nice Risotto,
Frans.
Old 29th August 2013, 10:24 PM   #2723
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Risotto ?
Frans, you @ the wrong side of the mediterranean
4 to get a proper Risotto.
Maybe Paella or lookalikes....
preregulatorpeterE-MAIL
Old 30th August 2013, 07:21 AM   #2724
nhinstruments
RCruz's Avatar
Paradise Builders
Frans.
After removing R105 and so disconnecting the led chain I still have 12.9v at the output.
RC
Old 30th August 2013, 11:33 AM   #2725
nhinstruments
RCruz's Avatar
Paradise Builders
Finally nailed it
After some mind stretching I decided to replace the mosfet driver bjt with a stronger one (highe hfe) and now everything works normally.
Now is time to build the external riaa filter for both boards.
PS: Led testing with a 9v batt can be a total disaster.... I managed to burn some leds this way and replacing them proved very board damaging.... DO NOT ATEMPT THIS AT HOME.
RC
Old 30th August 2013, 11:37 AM   #2726
R.I.P.
Originally Posted by RCruz View Post
.................. I decided to replace the mosfet driver bjt with a stronger one (highe hfe) and now everything works................
What was the old hFE and the new hFE?
regards Andrew T.
Old 30th August 2013, 06:54 PM   #2727
nhinstruments
RCruz's Avatar
Paradise Builders
Old 370.... New 450... strange isn'it ?
RC
Old 31st August 2013, 09:43 AM   #2728
R.I.P.
That is very strange.
20% more hFE does not seem like the change that cured the problem.
Look for something else.
regards Andrew T.
Old 31st August 2013, 12:10 PM   #2729
YNWOAN is offline YNWOAN  United Kingdom
YNWOAN's Avatar
I just got my Paradise up and running yesterday and am listening to it now - simply astonishing - the best phono stage I have ever heard - I can't praise it enough!
Old 31st August 2013, 12:15 PM   #2730
Marra is offline Marra  United Kingdom
Paradise Builders
Good to hear/see.Have you and Si been able to do a comparison between power supplies?
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 01:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
