Paradise Builders
Paradise Builders
Old 21st July 2013, 06:33 PM   #2611
amsoque is offline amsoque  Romania
Come on Alfred, why do you do that? we want the Calvin Buffer!
Is the little PCB double sided?
Old 21st July 2013, 10:03 PM   #2612
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Looks very good.
Old 22nd July 2013, 06:08 AM   #2613
Also, 26Vdc is the MINIMUM recommended input voltage for the PSU.[/QUOTE]
Hi Frans,
in a previous post it was stated that the input voltage have to be between 25 and 26 V. Now, you say minimum 26 and SQ have 28 V. That add quite some heat to the power transistors.
So, it's better with 26-27 volts?
Old 22nd July 2013, 06:10 AM   #2614
Bksabath is offline Bksabath  United Kingdom
Banned
Calvin Buffer one stereo set for me as well please
Old 22nd July 2013, 06:53 AM   #2615
Calvin is offline Calvin  Germany
Calvin's Avatar
I could ask mild mannered Calvin´s alter ego Stupendous Man to take Buffers from Alfred send to me to a Blackforest mountain in a thunderous night and speak a stupendous motivation sermon.
Something like: Come on You little su***r. Get up and going, or I´ll have Your 6-lettered butt fried to a crispy crunch by the next lightning!"
Well, if That doesn´t help ......
jauu
Calvin
Old 22nd July 2013, 07:15 AM   #2616
Abraxas336 is offline Abraxas336  Europe
Abraxas336's Avatar
@audiomania - I used the paradise only yesterday for a longer period and it got too hot for my taste. I consider venting the lid.
Gruenschnabel
Old 22nd July 2013, 07:58 AM   #2617
hesener is offline hesener  Germany
Paradise Builders
jauu
Calvin
Paradise documents are here: Link list
Old 22nd July 2013, 08:35 AM   #2618
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Using a shunt supply (any ) always creates the need for a ventilated box. The Paradise shunt is not different
Old 22nd July 2013, 08:37 AM   #2619
FdW's Avatar
Paradise Builders
Hi Frans,
This has been discussed may times the 26Vdc is the absolute minimum, different people have reported no improvements above this. Up to 28Vdc is allowable (each Volt adds 150mW dissipation) but be sure to have a well ventilated case. (Case not closed ).
Old 22nd July 2013, 11:05 AM   #2620
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Ok,one pair of buffers for me 2.
Regards Åke
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 20th May 2018 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
