Paradise Builders
Paradise Builders
Old 12th November 2012, 10:58 AM   #251
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That will work.
Old 12th November 2012, 11:03 AM   #252
hesener is offline hesener  Germany
Paradise Builders
Oops... it is NOT 6x33nF, only 1x33nF... the cap values given are the TOTAL value. That's why they have the same component indicator, perhaps I should have been more explicit with this.... thanks Salas for moving that comment over from the other thread
Old 12th November 2012, 11:11 AM   #253
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
This will be mentioned in the expanded Builing Guide.
preregulatorpeterE-MAIL
Old 12th November 2012, 11:12 AM   #254
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Paradise Builders
Aha, now its clear. So we need a bank of whatever good caps matched between channels for 33.3n and 11n. Roger
Old 12th November 2012, 11:27 AM   #255
Ricardo came up with some alternative values for a total flat result. The recommended values give a slight lift in the deep bass like plus 0.75dB at 20Hz.That is the JG-MiiB house curve.
Old 12th November 2012, 11:38 AM   #256
Paradise Builders
grooooovy, baby
Old 12th November 2012, 12:36 PM   #257
I like that tuning. Makes some lesser recordings sound acceptable.
Old 12th November 2012, 02:08 PM   #258
Paradise Builders
Default Updated assembly guide
See attached, this is just a little update regarding the RIAA components:
The values in the schematic are the total values (for both R and C), so in order to get there put as many caps in parallel as needed, same for the resistors.
Old 12th November 2012, 07:36 PM   #259
reins is offline reins  Germany
Default Balanced out?
has the board any support for balanced output? I think not. I remember I had read something in the mpp thread, but couldn't find it.
Has anyone thought about a balanced output, maybe with DRV134?
Best regards
Stephan
Old 12th November 2012, 07:44 PM   #260
Paradise Builders
Hi Stephan, no there is no balanced out. you would have to use a differential amplifier or transformer for that. I believe there is a fully balanced version in the works, not sure it is done yet.
(Shouldnt say this here, but I am using a FPS from Joachim Gerhard at home, which is fully balanced from input to output - it sounds very very nice, but the Paradise has something special that makes it somewhat outstanding to my ears.....)
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
