Paradise Builders - Page 243 - diyAudio
Old 22nd June 2013, 06:07 PM   #2421
amsoque is offline amsoque  Romania
hi.
why it's that bad to thight thermo-couple the transistors? That is what I understand by using a thin strip of copper. My solution is to fasten all the transistors in each stage in a bouquet with a strip of copper, soldering them to a little pcb, then to the main pcb.
Old 22nd June 2013, 06:27 PM   #2422
and if the paradise goes balanced, what with the amplifier.? I think already to add balanced inputs to my amplifier because my Oppo has balanced outs, but I can't figure it how. Is it worth to add a balanced input stage to an amplifier that is not designed in this way?
emil
Old 22nd June 2013, 06:39 PM   #2423
FdW is offline FdW  Netherlands
FdW's Avatar
emil
Have a look here Masterpiece
Old 22nd June 2013, 06:52 PM   #2424
thanks Frank. Is the thread about a balanced version of the Paradise?
Old 22nd June 2013, 07:05 PM   #2425
FdW's Avatar
Sort off, just go there. I'm sure Stefano will be a good host ohhh ehhh the name is Frans
Old 22nd June 2013, 08:13 PM   #2426
sorry .... Frans. I'll take a look. have a nice week end
Old 23rd June 2013, 09:45 PM   #2427
I use this thread now for an off topic question related however to the shunt regulator. Sorry!
The question: how could I get 26 -27 volts from the shunt regulator used in the paradise? I need a shunt to supply the voltage for a preamplifier.
Which are the differencies between Salas shunt and this one? Bref, I want to supply the preamp stage in my integrated NAD 375 from a shunt instead the simple regulator that is used. The NAD 165 preamp use a shunt instead, but it's a classic design, with a zener diode, not with leds and other spices. So, what do you recommend?
Ricardo, do you hav an ideeea what kind of improvements DYNAVOX.CH brings to the Swiss version of NAD they sell?
Old 24th June 2013, 11:22 AM   #2428
RCruz is offline RCruz  Switzerland
RCruz's Avatar
I have seen some revamped Myryads and it seems they have better psu's and caps, but I had not the opportunity to compare.
RC
Old 24th June 2013, 12:31 PM   #2429
FdW's Avatar
Add more LED's to the chain of LED's or replace them all with a zenerdiode of the desired voltage - 600mV or replace one LED with a zenerdiode(26V) - LEDcount * 1.8V - 600mV.
Old 24th June 2013, 12:33 PM   #2430
FdW's Avatar
The big difference is the CCS.
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright 1999-2017 diyAudio
