Paradise Builders
Paradise Builders
Old 20th June 2013, 10:57 AM   #2401
amsoque is offline amsoque  Romania
what is the use of a Calvin Buffer? Sorry for my ignorance. I looked in the buffer's thread but I didn't get it
My 700+700 Bc ( plus the difference to 50 euros the minimum value for the order - a ERSA RSD 80) are on their way. To me. Are anyone using the Ersa RSD 80? I have been using some ERSA equipment and I'm content with it.
Old 20th June 2013, 12:54 PM   #2402
hesener is offline hesener  Germany
Paradise Builders
the calvin buffer can replace the onboard buffer, and has much stronger drive capabilities, sounds clearer and more detailed. The onboard buffer is very good, but this one is better especially when the line stage has low input impedance or long cables are used. It sounds clearer and more transparent, in my opinion.
Paradise documents are here: Link list
Old 20th June 2013, 02:07 PM   #2403
RollE2k is offline RollE2k  Sweden
does anybody know of a discrete output stage that at the same time does convert SE -> BAL? I would like balanced output since my amp is balanced input. Of course i could run it through a transformer, but that feels like the wrong way of doing it.
Old 20th June 2013, 03:45 PM   #2404
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I think you can use a chip from That Corporation.
It sounds very good :
THAT Corporation 1606/1646 OutSmarts Balanced Line Driver ICs
Old 20th June 2013, 04:56 PM   #2405
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise Builders
Cool, that looks like it will fit in my current cases, result!
Paradise Pre-reg PSU PCBs
Old 20th June 2013, 05:31 PM   #2406
Thanks for the tip Joachim, but i would perfer any discrete solution, because i tend to think that IC's sound quite dull. Of course it would be possibly to try that IC, but then i could probably just use a transformer (which i already have).
I was just thinking if there was anybody sitting on a discrete se->bal driver stage design that could be used. Not for gain, but rather one less stage to add distortion.
Old 21st June 2013, 06:08 AM   #2407
Calvin is offline Calvin  Germany
Calvin's Avatar
just add a differential stage ahead of two buffers, or..
add an inverter ahead of one of the two buffers.
jauu
Calvin
Old 21st June 2013, 06:16 AM   #2408
Paradise Builders
jauu
Calvin
Would you have a suggestion for a differential stage with a gain of 1? I kind of have the same issue.....
Old 21st June 2013, 06:25 AM   #2409
A cacoded J-Fet with shunt feedback ?
Old 21st June 2013, 06:32 AM   #2410
There are some details missing but this is the principle .
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
