Paradise Builders
Paradise Builders
Old 5th November 2012, 08:13 PM   #221
pdul is offline pdul  Denmark
the solderings look good, and whats the chance of making bad solderings in the same place, on two such big boards
Old 5th November 2012, 08:15 PM   #222
With the opamps in, both measures the same
Old 5th November 2012, 08:17 PM   #223
The sailing offset of +/- 100mv as if it were slowly sampling a sinus
Old 5th November 2012, 08:34 PM   #224
We now have an ADconverter with a sampling frequency of 0,1 HZ
Old 5th November 2012, 08:46 PM   #225
hesener is offline hesener  Germany
Paradise Builders
which opamps are you using? sounds like it is oscillating with the servo cutoff frequency.... I used OPA134 with great results. I think Joachim mentioned once that they need to be FET inputs.....
Old 5th November 2012, 08:49 PM   #226
Opa 134 and i have tried AD711 briefly just for the experiment
Old 5th November 2012, 08:49 PM   #227
Both fet inputs
Old 5th November 2012, 09:34 PM   #228
I have now tried to change the 1uf bypass of the opamp to 220nf, and the offset is still wandering, but with only +/-50mv
Old 6th November 2012, 09:02 AM   #229
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Cool.... If you get it to + - 10mV it might not be audible
RC
Old 6th November 2012, 10:42 AM   #230
nhinstruments
RCruz's Avatar
Paradise Builders
I have been measuring the output of my running paradise and it wonders between +12mV and -5mV.... It sounds wonderfully as is.
RC
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 02:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
