Paradise Builders - Page 226 - diyAudio
Old 22nd May 2013, 01:17 PM   #2251
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Abraxas336 View Post
Something like this
I'm learning Fransh. (was more interested in the 2-how, than the ddrc part)
With mc-phono stages and transformers sharing one bed, sounds more like the steel case blanket is the main trespasser.
I'd either shoot the transformers, or the box.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 22nd May 2013, 01:39 PM   #2252
FdW is offline FdW  Netherlands
FdW's Avatar
That is what I thought (I think ), so I did say 'isolate them from the outer box, and (possibly) add inner boxes' (or something of that meaning )
Flickr Search: riaa
Old 22nd May 2013, 03:00 PM   #2253
MiiB is offline MiiB  Denmark
And twisted, I use three Teflon isolated solid-core wires (+/-/GND) twisted together and then put into a shield, shield is then grounded via a resistor in amp end.
Old 22nd May 2013, 08:07 PM   #2254
berndt is offline berndt  United States
Originally Posted by FdW View Post
This may unconfused you Please take notice of the fact that the suppliers of these devices took the liberty to show them (presumably there best (photogenic) side) from different sides, this may have been cause of some confusion
I was referencing the k170 drain which the Toshiba datasheet shows the drain being on the opposite side of our pcb label.
Old 22nd May 2013, 11:35 PM   #2255
pdul is offline pdul  Denmark
Back to irish dansers, start the music
Old 23rd May 2013, 11:23 AM   #2256
Flickr Search
How am I supposed to think what you thought, I can barely keep up with your expanding vocabulary.
Out of curiosity, with 2 amp cases, why all of 1 channel in 1 box and horizontal copper, instead of keeping power supplies well separated, but with vertical plumbing ?
(flickr search reads a bit odd)
Old 23rd May 2013, 11:50 AM   #2257
FdW's Avatar
Both cases are complete RIAA systems, the dark-texted one is MM and the light-texted one is MC. The inner boxes are, PSU(RIAA), RIAA, ADC(196/24), PSU(ADC) and Mains-Filter(Smallest box) as you may have deduced (I thought so ). There is no (not even a hint of) hum (net related) in the RIAA's.
Old 23rd May 2013, 02:35 PM   #2258
Any specifics on the various riaa curves? Relative sound qualities? Merits of different resistors?
Also struggling to interpret the assembly on the pcb. Is it possible to have a break down of this specific section? The one part of the pcb guide w/o numbers...
Old 23rd May 2013, 07:23 PM   #2259
hesener is offline hesener  Germany
hi berndt, you arrived at the inner sanctum of "bastling" right now! the values indicated in the schematic, which are supposed to be the end result of all parallel combinations you may want to put in there, will give you the groovy JG-MiiB house curve, a great place to start. the asse,bly guide has more proposals, looking for more neutrality, but that will all depend on your system and in particular on your loudspeakers.
keep bastling.....
Paradise documents are here: Link list
Old 23rd May 2013, 10:01 PM   #2260
Thank you hesener! The standard house sounds fine, would it be possible to just print a picture of what value goes where using the group buy Wilma caps? The build guide assumes that I can figure out which block on the riaa pcb coincides with the schematic, and I don't really get it. Also, for the house riaa are the pcb listed resistor values used?
Thanks in advance for your time and attention.
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright ©1999-2017 diyAudio
