Paradise Builders - Page 218 - diyAudio
Old 9th May 2013, 02:20 AM   #2171
Joachim Gerhard's Avatar
The current mode approach, maybe i am to stupid to explain that a transimpedance RIAA just does that.
Old 9th May 2013, 02:39 AM   #2172
If you want to be artistic use this :
http://www.lundahl.se/pdf/1940.pdf
Old 9th May 2013, 03:33 AM   #2173
Stefanoo's Avatar
Originally Posted by Joachim Gerhard View Post
I do not have an opinion, that is the difference. Otherwise i could not design.
I would say that i designed more top High End products then many here.
I won listening contests, got title pages, interviews etc.
I certainly do not have a problem to judge a design by listening alone and i have a panel of famous and experienced people that i trust.
Take the Calvin Buffer for example. It measures better and it sounds better.
What you also have to consider is that in the Paradise and Masterpiece we use CONSTANT CURRENT to supply the RIAA. That way dielectric absorption and ESR really do not play a big role. The impedance of the mirrors is so high that impedance changes in the caps are swapped. I call that a big advantage. What i think is audible is the mechanical design of the cap and V-Caps may have an advantage there or not.
I also said before that a GOOD sounding amplifier that measures not optimum may simply hide flaws in the recording. You only know better when you have heard true transparency.
Don't want to continue this subject on this 3d as I don't want to spam it more with useless crap...maybe one day we can open up a dedicated 3d and do a shoot out of cap or wires or other foolish audiophiles fetish and maybe you can have fun finding a justification for the different sounds!
Stefano
Old 9th May 2013, 08:24 AM   #2174
Benedetto's Avatar
Originally Posted by Stefanoo View Post
Dude chill out!! I have no economical interest with vcaps so I am not advertising anything!
Like Jacco said I have organized the GB and I would be curious to know how they liked it!!
If you don't like my post you have no rights to attack me!!
So one more time chill out!!!
Hi Stefano,
you know i know everything you did to promote those caps.
I believe you have no financial interest in this case.
I did not attack you.
On the other hand,
until now the response of those who bought theese little creeps
are not as enthusiastic as expected.
The only thing i've asked for was;
allmost everybody on any paradise-thread had to read constantly
about theese thigies, boring.
I do not think they fit to everybodys taste in every circuit.
preregulatorpeterE-MAIL
Old 9th May 2013, 08:34 AM   #2175
Abraxas336's Avatar
I know this is going to expose once more how little I understand but I need to ask anyways - whats the input impedance of the paradise without resistors in parallel?
Reason for my question is I am going to implement a rotary switch for input resisors and I'm trying to figure out how high values work. E.g. there are Grados that work best around 47k. At this point the input impedance of the circuit probably becomes a factor?
Sven
Gruenschnabel
Old 9th May 2013, 08:53 AM   #2176
hesener is offline hesener  Germany
It is about 10kOhm. Paradise is really made for MCs. In my opinion, you should not run it without input resistors, and my estimate fo the highest input resistor you should put is probably around 3...4k. But I hope Joachim can shed a little bit more light on this subject....
Paradise documents are here: Link list
Old 9th May 2013, 10:44 AM   #2177
Alfred, this is correct.
A BJT input like in the Paradise does not have a very high input impedance as is possible with Fets.
Old 9th May 2013, 10:50 AM   #2178
Abraxas336's Avatar
Thanks Gentlemen.
Gruenschnabel
Old 9th May 2013, 01:29 PM   #2179
Stefanoo's Avatar
Originally Posted by Benedetto View Post
Hi Stefano,
On the other hand,
What response have you seen that I didn't?
Please link them as the only feedback I got so far was only this one and seemed to be fairly positive.
Originally Posted by quan View Post
I have done my and definitely well worth all the money. For some reason the synergy in my system is mind blowing. What i did as stated before was the green end of the lead of the cap goes to ground. I just use the DMM and check the riaa grounding ends and just solder the cap in.
Stefano
Old 10th May 2013, 11:03 PM   #2180
My Paradise Boards are here!! They look amazing and I want to give a special thanx to Hesener for doing all the work, to give us such a wonderfull product!!
Now we have a look how to implement the Calvin Buffers onto the Board :-)
Paradise phono stage hesener Group Buys 1375 19th September 2016 02:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright 1999-2017 diyAudio
