Paradise Builders
Paradise Builders
Old 8th May 2013, 05:48 AM   #2151
quan is online now quan  Australia
Originally Posted by sq225917 View Post
I'd certainly give it a go were a pcb available.
Me too.
Old 8th May 2013, 08:06 AM   #2152
hesener is offline hesener  Germany
Paradise Builders
Here is the full schematic of my implementation. Please note I have replaced R14/R16 and R17/R19 with a 1kOhm trimpot each, but I just set them to the value the simulation indicated. In the Paradise, the buffer is inside the servo loop, so adjusting the offset would have to be done outside. The output zobel is not shown here but implemented just as in Calvin's schematic.
I will look into a little PCB for this....
Paradise documents are here: Link list
Old 8th May 2013, 08:15 AM   #2153
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Thanks Alfred. I am a bit confused about R7 and R15.
Old 8th May 2013, 08:16 AM   #2154
The output is behind R3 ?
Old 8th May 2013, 08:40 AM   #2155
Paradise Builders
Sorry I left those in. Yes, R7 is just an input resistor and has no function in the circuit. Its parallel to a voltage source so it does not affect simulation. R15 is the output resistor I used in the simulation, just to have some load on the output. The output is just below R3.
Old 8th May 2013, 08:46 AM   #2156
Paradise Builders
Actually, C1 and C2 might be just a touch too small, there is a little overshoot in the response around 10MHz but thats the values I had at hand... I'm so lazy...
Old 8th May 2013, 09:14 PM   #2157
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
so how does it sound?
Stefano
Old 8th May 2013, 09:41 PM   #2158
Paradise Builders
hi Stefano, check post 2147, its all there..... in short: great!
Old 8th May 2013, 09:49 PM   #2159
Stefanoo's Avatar
thanks for the review.
I think that this buffer gets very likely approved for Masterpiece too.
Also, on your picture I can't see what RIAA caps you are using at the moment!
Do you have the V-CAP on? I have never heard back from you on how you liked the upgrade.
Stefano
Old 8th May 2013, 09:53 PM   #2160
Paradise Builders
still the Wima caps, unfortunately. Still, it sounds very nice. Vcaps will be the next upgrade, they are sitting there and waiting for me to find the time. Plus, a few more modifications- some exotic input trannies, a new servo, cooling for the input stage, .......
on my way to the Paradise Platinum Extreme......
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 Yesterday 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
