Paradise Builders
Paradise Builders
Old 17th April 2013, 01:58 PM   #2091
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Here is an example based on the INA163 :
Calvin-phono/PlatINA en - calvins-audio-pages
Old 17th April 2013, 02:04 PM   #2092
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Thank you JG
Is INA163 a fet imput device ?
RC
Old 17th April 2013, 02:30 PM   #2093
I do not think so, it is BJT.
Old 17th April 2013, 03:26 PM   #2094
Bksabath is offline Bksabath  United Kingdom
Banned
Hi Riccardo I have posted a while ago my LT1028 balanced
Maybe Joachim remembers?
Using complete INA limit resistor value choice? 3 K and 6 K for 163 while discrete 3 LT1028 alowd for much lower values.
Worth looking at FDW balanced ?(yes I know I need to get back to it SORRY is not forgotten)
Old 17th April 2013, 03:44 PM   #2095
nhinstruments
RCruz's Avatar
Paradise Builders
Good post.... you read my mind... there might be limitations due to INA input imp
Is LT1028 jfet input opamp ?
Can you find your post about the balanced input ?
RC
Old 17th April 2013, 04:06 PM   #2096
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Ricardo,
noise figures in the order of 1nV/√Hz or lower are achievable only with bipolar input.
Old 17th April 2013, 04:09 PM   #2097
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Why the question mark, and where are the listening reports?
http://www.diyaudio.com/forums/analo...aa-preamp.html
Old 17th April 2013, 04:25 PM   #2098
Banned
Long time ago here a couple of preliminary drawing (I am sure you can do better than me)
One is Split passive and did run for couple of years try ed AD797 but was a bit to metallic
second was going to be, till I got infected by MPP and decided to try and learn sumthink about transistors, tanks so much, to late now to realize that Public forum is not right place.
LT1028 is BJT low noise voltage wise Current wise noise is sort of forget to mention it so data sheet looks better .
But said before Frans got better...
Cant promise much all old file are in secret puter never connected to intra web at present in the loft untouched for quite a while
Old 17th April 2013, 06:14 PM   #2099
Why the same opamp for the differential gain stage ?
Old 17th April 2013, 06:17 PM   #2100
nhinstruments
RCruz's Avatar
Paradise Builders
Thank you. Two servos and riaa filter around feedback loop.... not my piece of cake but invaluable info nontheless regarding balanced topology
RC
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
