Paradise Builders - Page 207 - diyAudio
Old 15th April 2013, 05:16 PM   #2061
MiiB is offline MiiB  Denmark
You Can use a diode on the rails of the front end of a power amplifier where they can prevent the rails sagging if there's a big power draw..for class A circuits you want the constant current draw to form a R-C filter there diodes would chop of the currents in a not so desired way
Old 15th April 2013, 07:49 PM   #2062
Nick77 is offline Nick77  United States
Trying to rid a little hum i am getting only once the cart hits the record. I can only hear it at about 3/4 volume plus but gets noisy after that.
I have a DCB1 without gain so i have to run the volume pretty high. If i disconnect the TT ground the hum increases dramatically.
Havent cased the PS yet, so there is no iec ground. RCA wire is Juniper with cotton, if that might be an issue? Any thoughts, otherwise sounds sweet!!
Old 15th April 2013, 07:59 PM   #2063
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Try moving the trafos away.... this is a 60 plus dB so it can amplify a lot
RC
Old 15th April 2013, 08:08 PM   #2064
FdW is offline FdW  Netherlands
FdW's Avatar
First move the transformers way out of the way Then have a good look at the grounding schema in the building guide
Old 15th April 2013, 08:30 PM   #2065
Banned
The ground vire on the plug soket is it disconnected?
Noughty Noughty
Where is case ground? Star?
Both signal grounds connected (ground loop) and providing ground return for the lot trough your pre?
Old 15th April 2013, 08:45 PM   #2066
RollE2k is offline RollE2k  Sweden
Joachim Gerhard: How did it go with the balanced input stage for the Paradise? :-)
Old 15th April 2013, 10:32 PM   #2067
Joachim Gerhard's Avatar
It would need too many changes. We have a new thread now called " Masterpiece" where we do a balanced phono stage that has a lot of the Paradise genes.
Old 15th April 2013, 11:31 PM   #2068
Circuit of post 588 on the Masterpiece thread seems to be working.
I found what i think is a better buffer though so this is still a work in progress.
Old 15th April 2013, 11:39 PM   #2069
I have being asked how a balanced output can be added to the Paradise. Unfortunately i have no idea for a simple modification but what works very well is this :
THAT Corporation 1606/1646 OutSmarts Balanced Line Driver ICs
Old 16th April 2013, 12:59 AM   #2070
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
the caps
KP72, very nice.
Are remakes of the Siemens B33051/61 film&foil series, but in an epoxy sealed plastic cannister.
[could be had 1% accurate up to 100Vdc, should tell something]
President Dwayne Camacho says you should drink Brawndo : It's got electrolytes
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright ©1999-2017 diyAudio
