| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
That's great Joachim. Thanks for all your help.
Mas |
#13 | |
please see attached. This is rev 1 and I hope to have included most of the comments I have received from the beta builders, plus my own experience. We have tried to think about the most common issues and provide explanations, let's see if you can find more... In fact, the R3 should be a breeze to build. If you are careful with that soldering iron, and putting all those LEDs the right way, and don't mix up the PNPs and NPNs, you should be good to go pretty quickly. The PCBs do NOT have the component designators printed, but the component values. For development and trouble shooting work that might make it more difficult, but for building (especially for the less experienced builders) that should make it more easy - painting by numbers, so to speak.... ;-) Attached are also the schematics of the amplifier and regulator, with typical voltage levels. These are from my Paradise, while it was still warming up, so please don't get nervous when yours are not matching 100% to these - if you are in the "ballpark" thats good enough. (For the pro's, you will note that I also have a little offset around the input stage... ouch...) Hope you like this stuff, I will try and update the builder's guide as we go along and repost.... |
#14 |
Looks extremely well done at a first glance.
Thank you again for all your efforts, Alfred.
Best regards: Holger www.holgerbarske.com - Deutschsprachiges Paradise-Support-Forum |
#15 |
Thank you again for all your efforts guys. The instruction is clear and precise.
Great work |
#16 |
Ditto Great work
#17 |
Very good work, Alfred.
#18 |
#19 |
Bravo
#20 |
Very, very good, you all have something to do (while I am away)
good luck to all.Regards, Frans.
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
