Paradise Builders Paradise Builders - Page 197 - diyAudio
Paradise Builders
Paradise Builders
Old 1st April 2013, 01:01 PM   #1961
heinz1 is offline heinz1  Europe
Originally Posted by Nick77 View Post
Okay, i coulda sworn someone posted a picture of the board with numerical reference.
Thanks.....
#1852
Old 1st April 2013, 01:12 PM   #1962
Nick77 is offline Nick77  United States
Originally Posted by heinz1 View Post
Bingo! Thanks........
Old 1st April 2013, 02:09 PM   #1963
studiostevus is offline studiostevus  Netherlands
Originally Posted by analog_sa View Post
I need to drag the boards back from the cupboard and measure again, but i think mine measured a rapidly fluctuating dc within 120mV. Could it be your results are better as your input caps are 2 x 4700 as opposed to mine 2 x 6800? I seem to recall Joachim mentioning something along these lines. Maybe further reducing these caps and speeding up the servo will bring some improvement.
Any possibility to improve the stability of the front end?
PMA, what do you think?
Analog_SA: Was this problem solved eventually?
I see two dancing lines on my scope moving, as you can see here (http://www.youtube.com/watch?v=xiHFP1aqjbQ). This is taken with 20mV/div. The pcb's were placed under a box to minimize airflow. If I take the box off, the lines are off the chart.
Normal or not normal?
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 1st April 2013, 05:29 PM   #1964
PMA is offline PMA  Europe
PMA's Avatar
Paradise Builders
Can you change your time base to slower one? Like 200ms/div or so.
Old 1st April 2013, 07:12 PM   #1965
hesener is offline hesener  Germany
Paradise Builders
Hi, this is the R2 layout, the R3 layout is identical except it has the input offset trimmer right next to the input connectors.
R43a-b are left of that, and reducing them gives the servo more "authority". This will help reducing the output fluctuations a little bit. You can try values down to 10k, i would not go any lower than that though.
You may also want to reduce the servo time constant, by reducing C5 to 470nF or 220nF, but at some point this will eat into the bass signals, basically acting like a rumble filter, and this is not the best-sounding way to implement that, according to the master...
Let us know if this helps!
Paradise documents are here: Link list
Old 1st April 2013, 07:13 PM   #1966
Paradise Builders
I see two dancing lines on my scope moving, as you can see here (Scope - YouTube). This is taken with 20mV/div. The pcb's were placed under a box to minimize airflow. If I take the box off, the lines are off the chart.
normal, according to my measurements. just be careful with those DC-coupled 1kW subwoofers
Old 1st April 2013, 08:24 PM   #1967
PMA's Avatar
Paradise Builders
Originally Posted by hesener View Post
normal
You must be joking. Are you pulling leg of the builders? You consider this "normal"?
Old 1st April 2013, 08:27 PM   #1968
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Yes. With 10k in parallel to the original resistors offset is now a few mV. As Salas mentioned in an earlier post during power on and off this goes off the scale, so a muting relay with a slow on, fast off is required.
Old 1st April 2013, 08:28 PM   #1969
Doppelkopf is offline Doppelkopf  Germany
normal
__________________[/U]
[U]
You have ever tried x-ono clone ?
Normal .
greatings , Dirk
Old 1st April 2013, 08:29 PM   #1970
analog_sa's Avatar
Yes, i have.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1375 19th September 2016 02:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2017 diyAudio
