Paradise Builders
Paradise Builders
Old 2nd November 2012, 09:50 AM   #181
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Originally Posted by Joachim Gerhard View Post
Any volunteer to check this ? I am out of time. I am leaving for Krefeld over the weekend.
There is the AAA analog show. The Paradise is playing in Andrejs system. Also in the Fast Audio room the "Tanzmusik" Phono with tone control i designed with Sigurd Ruschkowski and Ward Maas. I also show a subwoofer for the Kiso speakers from Japan. My new JG1 preamp is playing in Wolf von Langas system and i just finished my entry level preamp. Its called " Das unbeschriebene Blatt ". I do not know how to translate this into english. It has MM,MC, Line inputs, Line Out, Phono Direct, Line high pass filtered and a Headphone Out. i will have lots to do and explain.
I am missing this one too....
Looking forward to Holgarīs photos
RC
Old 2nd November 2012, 09:55 AM   #182
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The Blank Page, i like that translation.
Yes, Krefeld is pretty cool for us analog aficionados.
Old 2nd November 2012, 10:11 AM   #183
pdul is offline pdul  Denmark
Based on all those functions you described, it should be. Cand. Phono.
Old 2nd November 2012, 10:38 AM   #184
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Then I would propose 'Phony' instead of 'Phono'
Old 2nd November 2012, 11:10 AM   #185
nhinstruments
RCruz's Avatar
Paradise Builders
Hi Joachim
Where can I buy this type of cable ?
RC
Old 2nd November 2012, 11:10 AM   #186
Old 2nd November 2012, 11:13 AM   #187
Actually the " Das unbeschriebene Blatt" looks like a small mixing board in DIN A4.
Klotz is a famous brand of professional cables. I buy it in a local musicians shop.
Old 2nd November 2012, 12:02 PM   #188
nhinstruments
RCruz's Avatar
Paradise Builders
Tabula rasa.... (the human brain is a blank slate that is only shaped by his life experiences.) In his case a non affected preamp desing maybe
RC
Old 2nd November 2012, 01:25 PM   #189
FdW's Avatar
Paradise Builders
Not this one? Steven Pinker - Das unbeschriebene Blatt
Old 3rd November 2012, 01:31 PM   #190
Any suggestions, to how i can turn my paradise oscillators into phonestages?
Input is ok.
The testpoints measure ok.
Powersupply working ok.
But output is hyper, it wanders arround from +100mv to -100mv as if it were slowly sampling a big sinus
The same if i measure at ext riia, so i guess the buffer is ok too.
I have tried to half the value of the two resistors in the servo, with no changes at all.
I have connected 100k in series with 1nf to the output, and i can measure a lot of hyperdancing mv`s over the resistor, with the DMM set to ac
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 01:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2017 diyAudio
