| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#1631 | |
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
#1632 | |
#1633 |
diyAudio Chief Moderator
What is the output impedance sim of the total reg for 70mA spare above load?
#1634 | |
). If this is what you wanted to know
#1635 |
Also I do not think this is realistic, in real life, the PCB (layout and track resistances) is not modeled in there. SO this is why I never posted sim results like that
#1636 |
Energize the main voltage source for ACampl=1, also the load sink. Run an AC sweep on the output with the probe off .params prb=0 go click to the chart's left side and ask for logarithmic. What you see complies to Ohm scale too now. That way you can see what it does across wide band.
#1637 |
Jack had run the 1.1 on AP2 once and it was bang on to the sim and actually a bit better than the model for supersonic. It can be near if you will model the lines inductance and their resistance. Still 0.62mOhm strikes me as a bit optimistic for the limited Gfs a 9610/610 can have when shunting 50mA. Even on optimal local node.
#1638 |
All quiet on that front. I just examined it up to the phono after doing the rails jumpers. No oscillations nowhere. The residual noise looks bumped up enough from when PSU alone is a difference. But now there is a multifaceted active load entering the picture we shall not forget. Or it has to do with the large loop area the all in one ground plane has. To remind, this is a fast TOSHIBA TO-220 BJTs build with NO 1uF capacitors bypassing the phono lytics but the 0.1uF cap across rails for the OPA is still there. 10uF PSU caps are Nippon KMQ. It also has 10K instead of 150K servo injections showing insignificant offset and -0.136VDC on OPA pin 6. Hfe is generally well near all over with lowest finds used in the CV/CCS part. IDSS of K170s used was around the 7mA mark. J310s just random.
To conclude my practical points feedback, I recommend 0.6mm solder wire because there is not much pad real estate and to finger touch them as little as possible. They tend to oxidize too fast. Had to use the flux pen often after a few days to revisit it although I used a 60W Metcal Iron and lead solder. I also consider a delay on-fast release off output relay a must if care free on/off DC offset cycles are needed. It peaks high DC on output during those cycles. Hope those clues can come handy to some folks.
#1639 |
Let there be light !
#1640 |
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
