Paradise Builders
Paradise Builders
Old 31st October 2012, 09:32 AM   #151
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
I'm here, catching up with the 'after holydays work' and lurking a bit . I will check it out; yes it seems a bit low. This was discussed before, I will dig it up.
Old 31st October 2012, 09:35 AM   #152
FdW's Avatar
Paradise Builders
This is the one MPP #6462 it states that 24Vdc (on the input side) is the absolute minimum.
Old 31st October 2012, 09:37 AM   #153
FdW's Avatar
Paradise Builders
Originally Posted by pdul View Post
I just salvaged a nice transformer from a JVC home theatre, and measured it to 18,4-18,4v unloaded. with a simple prereg. and both paradise boards connected, i measure +/-23v and all the leds are glowing. Best of all the heatsinks cant be used as a stowe anymore, temp. around 40 degrees Celsius.
So how low can we go.
The 23Vdc is below spec you need a bit more.
Old 31st October 2012, 09:37 AM   #154
hesener is offline hesener  Germany
Paradise Builders
He sent me a message that he is "officially" back from vacation, so he should be here any minute ;-)
PS: Oh there you are....
Old 31st October 2012, 09:46 AM   #155
FdW's Avatar
Paradise Builders
A quick run in the simulator shows these output residuals for:
Green 25Vdc, Blue 24Vdc and Red 23Vdc.
As you see 23Vdc is marginal.
Old 31st October 2012, 09:51 AM   #156
pdul is offline pdul  Denmark
I dont know if it makes any difference, but the trannies i use are ON semi MJE15032/33
Old 31st October 2012, 09:56 AM   #157
It looks to me as 25 will be the minimum.
Old 31st October 2012, 10:05 AM   #158
FdW's Avatar
Paradise Builders
25Vdc is the recomended minimum as specified in Mpp #6462.
Old 31st October 2012, 10:06 AM   #159
GandRalf is offline GandRalf  Germany
GandRalf's Avatar
Anybody with a take on interconnects between preamp cabinet and psu cabinet?
Wire? connectors? Etc.?
For powersupply I use microfonplugs for radio devices like this.
Up to 60V and 1A.
Old 31st October 2012, 10:07 AM   #160
FdW's Avatar
Paradise Builders
Those will work fine
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 20th May 2018 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
