Paradise Builders
Paradise Builders
Old 26th February 2013, 10:24 AM   #1571
GandRalf is offline GandRalf  Germany
GandRalf's Avatar
Sorry!
Great Confusion!
Output Voltage is +15,57V and RIAA is 15,8V.
Servo Voltage (Pin6 OPA) is -18Volt!
Old 26th February 2013, 06:44 PM   #1572
hesener is offline hesener  Germany
Paradise Builders
Originally Posted by GandRalf View Post
Sorry!
Great Confusion!
hi Gandralf, something is going VERY wrong here. Looks like the servo is doing his job, though, and the problem is somewhere else. I suspect the current mirror around Q6-Q9, you may want to check if all those transistors are correct and working. The voltages on test points TP9 and TP10 should be as indicated in the assembly guide (-16.5V); if they are stuck at -18V then no current is flowing in that mirror.
Let me know if you can find the problem, alternatively send the boards to me (but within this week, please - have to travel end of next week.....)
Paradise documents are here: Link list
Old 27th February 2013, 06:50 AM   #1573
heijopo is offline heijopo
Hi guys
And it sounds very very good!!
Thanks to all who worked on it.
Greeting Heinz
Old 27th February 2013, 10:00 AM   #1574
GandRalf's Avatar
The current mirror :
TP9 -16,51V TP 10 -16,52V.
Emitter Q 24 -15,20V; Basis -14,62V
TP4 -14,51V
Changed Q7. -No difference.
Changed all Transistors in current mirror. -No difference.
Is it possible that Q99 causes such an error?
Old 27th February 2013, 12:14 PM   #1575
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
I had a similar experience once and found a shorted fet on the output buffer.
Please check the two top fets on the output buffer.
RC
Old 28th February 2013, 09:01 AM   #1576
Paradise Builders
yes, it could be the output buffer. according to these values, the current mirror is biased correctly. Something is pulling down the voltage at the connection of the mirrors.
Is there a voltage difference between "Ext RIAA" and the output?
... oops, just saw you already posted that value - yes it looks like Q99 has a problem.....
Old 1st March 2013, 08:04 AM   #1577
nhinstruments
RCruz's Avatar
Paradise Builders
Or Q90.
RC
Old 1st March 2013, 08:21 AM   #1578
pdul is offline pdul  Denmark
As mentioned earlier, i have tried my paradise, and the sound is amazing, but the gain is lower than the rest of my components ( I have to bottom my volumepot out to get a realistic listening level) So i just wonder if it is suppose to be like that, or if i maybe have made a blooper somewhere?
Old 1st March 2013, 08:25 AM   #1579
Pu Dynavector Karat17D2 32ohms loadresistor 100ohms output 0,2mv
Old 1st March 2013, 12:05 PM   #1580
Paradise Builders
that is a little surprising. I found it to operate on par with other phono stages and no big difference in gain (I seem to remember 60-65dB at 1kHz). If the tonality is correct (in other words, excluding any issue with the RIAA section), the gain should be more than enough, even with the lowish output voltage of your cartridge.... strange....
do you have the means to measure the gain, e.g. with a 1V sinewave input @ 1kHz, and a 1000:1 voltage divider (10kOhm : 10 Ohm) at the input, then the output voltage should again be 1V (since 1000:1 == 60dB)?
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
