Paradise Builders - Page 154 - diyAudio
Old 23rd February 2013, 05:47 PM   #1531
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Abraxas336 View Post
Salas - to be honest I don't know. Have it only for a couple of weeks. Will check.
Just gave it a try at X1 probes also and the only thing I could reliably capture from the circuit itself sans its dedicated regs was the 100Hz rectification residual breaking thru from the lab supply. Its the spikes in the graph.
Old 23rd February 2013, 05:54 PM   #1532
pdul is offline pdul  Denmark
Is it correct that the cutoff will be 1,59hz with 1uf, or am i completely of with my calc.?
Old 23rd February 2013, 06:02 PM   #1533
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by pdul View Post
I wonder if one of you math professors can help me out with the value of a seriescap for the output of the paradise, if it will be loaded with 100ko, and which kind of cap that is best for the purpose?
I believe 0.5uF would do it as it would cut freq below 3Hz.
The best are teflon caps
RC
Old 23rd February 2013, 06:03 PM   #1534
nhinstruments
RCruz's Avatar
Correct
RC
Old 23rd February 2013, 06:03 PM   #1535
Salas's Avatar
Cut-off frequency
fc = 1.59154943092[Hz]
Old 23rd February 2013, 06:58 PM   #1536
Thanks guys
Old 23rd February 2013, 07:00 PM   #1537
FdW is offline FdW  Netherlands
FdW's Avatar
Btw, the same ~90MHz are visibe on the input with a much lower amplitude of ~1mV
40mV near 100mHz almost a nice sinus, is a bit of an problem for the 100Mhz scope, and probably does not tell a lot about the original signal. I think that Salas is right, some strong signal induced by the environment. If (and only when) the RIAA has a proper box, you may be able to stop this signal by adding some ferrite beads in the input (and probably output and signal ground) wires.
If it is still a problem then (when boxed )
Old 23rd February 2013, 07:08 PM   #1538
FdW's Avatar
Originally Posted by Salas View Post
Cut-off frequency
Are you sure about that '2' (at the end)?
Old 23rd February 2013, 07:17 PM   #1539
Salas's Avatar
Blame the RC calc. I declare myself "not guilty".
Old 23rd February 2013, 08:39 PM   #1540
It is very important to get that right, otherwise the bass will sound flat
Paradise phono stage hesener Group Buys 1375 19th September 2016 02:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright 1999-2017 diyAudio
