Paradise Builders
Paradise Builders
Old 15th February 2013, 10:18 AM   #1431
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Originally Posted by pdul View Post
Do you have any experience with Vishay MRS25 1%?
Let me say a few things about http://www.vishay.com/docs/28724/mrs16m25.pdf.
In my opinion it looks like a reasonable, above average, performer. The tempco of 50ppm is not bad, but not very good also. Low tempco resistors do exhibit less thermal modulation. This is important, the resistor is advertised as a 600mW part, but at the specified 150C/W it will give you an temperature of 90C above environment and that makes the 50ppm significant. For me the true maximum dissipation for a resistor is at +20C, and thus this resistor, for me, would be used as an +/- 100mW item.
For long term stability I would like to see a 'glass' coted resistor. These are totally non-permeable (mostly by moisture) and the glass seems to withstand more thermic cycling.
Anyway, just some remarks Nothing said about the way they sound (I never used these).
Old 15th February 2013, 10:38 AM   #1432
noelectrix is offline noelectrix  Europe
noelectrix's Avatar
another pic of paradise . I did simple grounding and it is totally quiet. soundwise it startet with great dynamics but it was a little bright in my system with not very deep soundstage (a little metalised hüsker dü´sch). a post from RCruz encouraged me to play with just the 9.1k value of the RIAA and with about 9.3k to 9.6k i´ll find peace. Also the soudstage depth improved to be very good now. not shure if i had some oscillation. the improvement i felt in soundstage depth after installing the anti-osci-caps might have been a rather more psycolocical reason
so yes, it is a fantastic sounding stage. thank you!!
stefan
[IMG]Click the image to open in full size.[/IMG]
Old 15th February 2013, 10:45 AM   #1433
studiostevus is offline studiostevus  Netherlands
Nice pic!
So I have started the filling the pcb's I received some months ago. I am one of the Kit GB participants. So far so good, I had no problems finding matching 327/337's in my goodie bag, which made me pretty happy.
Now on to the next one:
- I did not get J310's, but got J109's instead... ok or no ok? I know the answer was given some time ago, but did anyone actually use them succesfully? Any other adaptations needed? Or better to look for some J310's?
- I did not get SK170's but got J107's instead... same questions. ok or not ok? Any experiences? Any adjustments needed to use the J107's? Or better to look for SK170's
- Do these (j)fets need to be matched in one way or the other?
- Do the LEDs need to be selected or matched?
Thanks!
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 15th February 2013, 10:46 AM   #1434
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Very nice Stefan.
What kind of PSU do you use ?
preregulatorpeterE-MAIL
Old 15th February 2013, 10:46 AM   #1435
FdW's Avatar
Paradise Builders
stefan
Nice, great looking build, have fun
Old 15th February 2013, 10:47 AM   #1436
Benedetto's Avatar
Nope
Old 15th February 2013, 10:59 AM   #1437
noelectrix's Avatar
Originally Posted by Benedetto View Post
Very nice Stefan.
the most simple. i had two 2x18V trafos. Just rectifiers and about 14.000 uF. no L´s no R´s (for what to use i´m too stupid to calculate ).
st.
Old 15th February 2013, 11:01 AM   #1438
FdW's Avatar
Paradise Builders
When using J109's in the PSU you may want to lower R108/208 from 3.3k to 1.8k, which will keep Id at 1mA. But if you leave the 3.3k resistors in place it will still work nicely at an Id of 600uA, it will lower the GBW a tiny bit. The point is you could temporarily use the J109 with the 3.3k resistors, and later replace the J309's with J310's while everything keeps on working
Old 15th February 2013, 11:01 AM   #1439
Benedetto's Avatar
@Stefan
FF this Year ?
Old 15th February 2013, 11:06 AM   #1440
noelectrix's Avatar
Hi Peter, I seriously think about joining FF this year.
hope to see you there,
st.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
