Paradise Builders
Paradise Builders
Old 31st January 2013, 09:38 AM   #1341
GandRalf is offline GandRalf  Germany
GandRalf's Avatar
The MC Silver is a High Output MC. 2mV may be to high for the Input of the Paradise. What Impedance Resistor do you use at the Input?
Old 31st January 2013, 10:09 AM   #1342
Libby123 is offline Libby123  Germany
You meen the R1b? It´s still 10kOhm.
Old 31st January 2013, 01:38 PM   #1343
hesener is offline hesener  Germany
Paradise Builders
You will need to put a resistor in parallel with the input (you can use the second input connnector on the board for that), which should be the appropriate input resistance for the cartridge. For a MC system, this could be between say 100Ohm and 2000Ohm - please check the documentation of your cartridge, pretty sure they recommend a value.
Old 31st January 2013, 02:17 PM   #1344
I found this http://www.benz-micro.de/high-fideli...nformation.zip
they say its between 2000 and 47000 Ohm on homepage but in this pdf it is 47000Ohm.
Old 31st January 2013, 02:40 PM   #1345
noelectrix is offline noelectrix  Europe
noelectrix's Avatar
Benz' own phonostage is loaded with 22kOhm. At least the low output Benz Glider really likes a rather high value. It gets a little more lively.
stefan
Old 31st January 2013, 02:50 PM   #1346
stefan
you meen 22k Ohm in Input (like hesener explaint) will do?
Old 31st January 2013, 02:55 PM   #1347
noelectrix's Avatar
exactly, from input to gnd.
st.
Old 31st January 2013, 03:03 PM   #1348
will try today.
Old 31st January 2013, 03:35 PM   #1349
Doppelkopf is offline Doppelkopf  Germany
Originally Posted by Doppelkopf View Post
Do i have to expect influence to the soundperformance of the Paradise when i reduce R43a/b ?
Is no one able ta answer this question ?
Or is it a stupid question ?
greatings , Dirk
Old 31st January 2013, 04:31 PM   #1350
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
There Are No Stupid Question Quotes
But I do not have the answer
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
