Paradise Builders - Page 133 - diyAudio
Old 29th January 2013, 08:56 AM   #1321
Default Fuse?
Hello,
I'm very happy with my paradise.
I've found no suggestions about the size/value of the fuse at the mains input.
I have a holder for 2 fuses there for both, + and -.
For testing I have two 2 amp. fuses in there, which are surely not the right value.
Best regards,
Christoph
Old 29th January 2013, 10:10 AM   #1322
FdW is offline FdW  Netherlands
FdW's Avatar
Originally Posted by brozatus View Post
Hello,
Best regards,
Christoph
PLEASE NOTE: This information is for the primary/mains-side of the device!
WARNING: BE VERRY CAREFULL WHEN WORKING ON MAINS CONNECTED CIRCUITS, ALWAIS UNPLUG FIRST!
The ‘Paradise’ system is using about 150mAac per supply, as there are 4 supply's this will be a total current of 600mAac.
When U are using a 28Vac transformer then this will work out at 600mAac * 28Vac = 17Watt, to this we allow some transformer losses and make it a nice 20Watts.
This 20Watts translates to (about) 100mA@220Vac or 200mA@110Vac.
Next what you need to do is find the transformer specifications; it will (most probably) specify a maximum primary current (that may be sustained indefinitely). The fuse you need to select has a value between 100mA@220Vac(200mA@110Vac) slow blow and the transformer specified maximum (also slow blow).
Practically, I would select a fuse 2 * the calculated value, that is 200mA@220Vac(400mA@110Vac), but it has to be below the maximum that is specified for the transformer.
All wiring on the primary/mains side of the system should be able to carry at the least this current, but preferably 5 times it (that is 1A@220Vac(2A@110Vac)).
These (above) are my 'ballpark'-guidelines this should be sufficient for any home audio appliance.
See also: http://www.optifuse.com/PDFs/FuseSel...Guide_RevA.pdf
Old 29th January 2013, 01:06 PM   #1323
Default psu: 2,2uF instead of 2,7uF ?
are 2,2 uF for the "counter oscillation caps" ok also? I dont have a scope and want to add them just to be shure. the 470pF I have in the right value.
tnx.
stefan
Old 29th January 2013, 01:08 PM   #1324
analog_sa's Avatar
No.
Old 29th January 2013, 01:24 PM   #1325
oh thank you
i got told there is no value like 2,7 to buy. now i saw it on the picture, there indeed is. rghhhhhh
thanks a lot
st.
Old 29th January 2013, 01:34 PM   #1326
FdW's Avatar
oh thank you
thanks a lot
st.
That is 2.2nF and 2.7nF, you will be fine with 2.2nF
Old 29th January 2013, 01:41 PM   #1327
Thanks, so IŽll try them out tomorrow.
st.
Old 29th January 2013, 02:30 PM   #1328
miepa is offline miepa  Austria
Default SMD cap, footprint 1206
Guys,
the SMD caps, footprint 1206 - C901, C901_1, C901_2, C902, C902_1, C902_2, C903, C903_1, C903_2
CAPS are available in FILM or CERAMIC - which one would be the better choice in the paradise
what are they for - are they really important??? because the manual says: THESE CAPS ARE OPTIONAL
Old 29th January 2013, 03:58 PM   #1329
hesener is offline hesener  Germany
Originally Posted by miepa View Post
Guys,
Please put ceramic caps. They are helpful in avoiding oscillations in the current mirrors, so if you do not have oscillations you can happily leave them out. As a safety measure, it doesnt hurt to put them in....
Old 29th January 2013, 07:19 PM   #1330
@Frans,
thanks for great helping with the fuses values,
Christoph
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright ©1999-2017 diyAudio
