| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#1241 |
#1242 |
#1243 |
Libby123, I do only answer questions regarding the PSU. And at some moments that is a day-job in itself.
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
#1244 |
#1245 | |
TP5 and 6 both are 16,55V TP9 and 10 both are -16,08V with the 2 220Ohm resistors the upper one (next to J310) -15,32V the lower one (next to 1M R) -18,11V |
#1246 |
#1247 | |
#1248 | |
While you are at it, please also measure the emitter voltage of the NPNs (Q32 / Q31 / Q30 / Q1)? many thanks |
#1249 | |
#1250 |
sorry but thats impossible. is the input shorted, or connected to GND with a low ohmic resistor? Then, the emitter votlage is the voltage from the connection between transistor and 33Ohm resistor, to GND / simply put the black cable of the DMM to Ground, and use the red cable to check all 8 emitter voltages..... thanks a lot and sorry if I have not said clearly enough whats needed...
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
