Old 22nd January 2013, 02:56 PM   #1231
miepa is offline miepa  Austria
thanks Frans. hope you would say so.
FP was my first choice.
Old 22nd January 2013, 03:36 PM   #1232
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by RCruz View Post
Did you check your caps voltage rating ?
Originally Posted by Libby123 View Post
no, as I would saying. I pulled out the plug as I saw the "liquid".
What is the voltage rating of the caps that blew ?
What caps are you using ? (Capacity uF Voltage rating V) it is written in the caps body.
You stated you used different caps because of the footpint...
RC
Old 22nd January 2013, 03:51 PM   #1233
I thougth it were the 6800 from GB that have the worng foot spacing, but it was the 4700 Caps that were wrong. So the "wet-ies" are the ones from GB = 6800/6,3V
Old 22nd January 2013, 04:14 PM   #1234
RCruz's Avatar
We need some voltage measurements.
I would visualy check all parts, remove the caps, power on and measure voltages on the empty locations of those caps.
RC
Old 22nd January 2013, 08:24 PM   #1235
quan is offline quan  Australia
Originally Posted by hesener View Post
yes exactly
Hi Alfred, change input loading to 22K and no changes in servo offset ie +5V so look like i will leave it at that. I will try to find the appropriate material for the faraday cages and re-do the groundings. Thank you so much. BTW is the picture in the build guide is your R3 ? How do you implement input loading switch if you don't mind me asking?
Quan
Old 22nd January 2013, 08:42 PM   #1236
So, I take some measurements:
First of all the power supply is +24,96V and -25,09V. OK or Not OK?
The board with the 2x 6800/10V at V+ broken
VCASCH: 14,4V
VCASCL: -14,4V
V+: +18,00V (trimmed)
V-: -18,00V (trimmed)
V- 4700uF -14,4V
V- 6800uF -5,6V
V+ 4700uF +14,4
V+ 6800uF -4V !!!!!!!!!!!!!!
I think thats it. But why?
Old 22nd January 2013, 08:43 PM   #1237
FdW is offline FdW  Netherlands
FdW's Avatar
Totaly o.k.!
Old 22nd January 2013, 08:44 PM   #1238
FdW's Avatar
O.k. to 4 decimals
Old 23rd January 2013, 09:36 AM   #1239
hesener is offline hesener  Germany
Quan
Hi quan,
thanks for the update, thats ok then. Yes that is my R2 build, working as advertised (in fact I had a great evening yesterday, listening to the Cowboy Junkies).
The input resistances in my case are Dale RN65 resistors (stepped 10 / 50 / 100 / 220 / 470 / 1000 Ohm) through a rotaty switch (C&K, with silver contacts). works just fine.....
Old 23rd January 2013, 09:47 AM   #1240
Hi quan,
Thanks Alfred, can you post a picture how it is implemented if it is not too much trouble?
Quan
Paradise phono stage hesener Group Buys 1018 3rd May 2013 08:56 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2013 diyAudio
