Paradise Builders
Paradise Builders
Old 19th January 2013, 06:05 PM   #1161
Bksabath is offline Bksabath  United Kingdom
Banned
Tanks Frans.
One more thing to watch out for is cheapo cables on budget TT Like my Project RPM 4
The cheap and nasty phono plugs have no insulation so they are connected to ground with the metal of the cheap and nasty piece of metal so there is a potential loop there.
Best thing one can do is to replace the wires straight from cartridge tags to the phono plugs.
I use 4 wires in pairs (L and R) in their own silicon sleeve and 2 Layers of cooper braid over the top of those
The cooper braid is connected on TT end with the ground cable from the arm and on other end has a lug for the connection to the Phono star ground
Old 19th January 2013, 07:10 PM   #1162
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Did you rewire your tonearm ?
RC
Old 19th January 2013, 07:59 PM   #1163
Banned
Yes I did a couple of years (maybe 4 or 5 ) back as I went Balanced INA with LT 1028
I am using single strand pure silver cores X 4.
Silver Insulated Wire Global Online Supplies - Product Line AG5494
This I have found is realy durable and light. Custom cables can be to heavy for same arms.
No broken wires at all while in use and abuse apart from solder joints.
Meybe I shuld have used the next size up
Old 19th January 2013, 08:32 PM   #1164
quan is offline quan  Australia
Thanks guys for the interesting discussions re grounding rules. Thanks Franz for the ground scheme- now i understand it a bit more. I find that if i used screen IC the noise level is higher? May be the screen created a ground loop?.
quan
Old 19th January 2013, 08:44 PM   #1165
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise Builders
Maybe the gnd on the rca sockets is touching the casework.
Paradise Pre-reg PSU PCBs
Old 19th January 2013, 08:49 PM   #1166
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
This is an interesting point, the RCA connectors in and out should be mounted (any way that is what I prefer) on a Plexiglas insert (inserted into the back panel) to be sure that no (not any) signal or signal ground wire touches the chassis at that point!
Maybe this remark should be added to the builders guide
You just can see the insert (just) on this picture Balanced RIAA preamp | Flickr - Photo Sharing! it is on the outside
Old 19th January 2013, 09:25 PM   #1167
Banned
quan
Easy sorted just cut the screen wire from the Paradise board before it reaches the phono plug
If those are grounded on the enclosure you won't need the binding wire to TT
Snip away one at the time and listen for results
Easy to resolder them in place later.
Me think Neutric phono plugs came with 2 plastic washers, fiber washers EG one find in Plumbing water taps kits are even better just drill oversize holes...
Old 19th January 2013, 09:38 PM   #1168
heinz1 is offline heinz1  Europe
Another possibility:
May I suggest that somebody of the design/construction team opens a wiki page for the Paradise?
Main Page - diyAudio
The wiki pages here are somewhat neglected here, but I consider this format as very useful tool for summarizing information.
On that page, links to the most important posts could listed.
Old 19th January 2013, 11:40 PM   #1169
Banned
Me not on that team
AS Mrs Perrine wuld say I am Just Lollygagging along with my mouth hanging open.
Old 20th January 2013, 03:53 AM   #1170
Thank you Franz. How do you implement input resistor loading switches? Can you show me a close-up image?.
quan
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 02:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
