Paradise Builders
Paradise Builders
Old 19th January 2013, 02:01 PM   #1151
Bksabath is offline Bksabath  United Kingdom
Banned
For grounding less is more
as using to many cables introduce a loop as cables lengths and resistances different this will cause a small difference in voltages that can be amplified
so one cable to one common point is the solution.
Old 19th January 2013, 02:14 PM   #1152
Banned
Add turntable and pre amplifier
For the turn Table this is normally double insulated same as to say it does not have a ground on the mains plug
so the screen wire for the arm is connected to the grounding lug on the chassis
This make a really convenient place where to connect the ground cables from the phono boards
Old 19th January 2013, 02:26 PM   #1153
Banned
Same cartridges use the left cold wire as ground as well but this is as far as I know for MM cart so no problems
And is your TT got a ground cable on the mains plug you don't need the connection to the ground lug (main rule for avoiding ground loops is use only one cable to each point)
So use insulated plugs or if those are not get your snips and cut the screen cable as the metal enclosure will became your wire.
Old 19th January 2013, 02:33 PM   #1154
Banned
Lets see what happens with normal cables when you connect Paradise to pre amplifier.
You get 2 relay nice and juicy ground loops
As normal cables have a signal wire (hot) and a screen connected to both plugs
so again snip snip the screen at the pre amplifier end as this is connected to the mains with the ground cable on the plug
Do not disconnect the mains earth cable on the plug as this is there for your own safety
One can go further and squiggle the amplifiers on the drawings but I think I bored you already so ....
Old 19th January 2013, 03:06 PM   #1155
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Originally Posted by Bksabath View Post
Here is Sketch of bus of stars
this is if you use 2 box set up
the input and output cables sockets must be isolated from the enclosure as those are grounded on the PCB
This means that 4 wires came from cartridge and all 4 are isolated from the ground
Mains ground to star/chassis-ground connection needs to be decoupled (DDCR) otherwise the mains-ground in the player connected to the player chassis will form a ground-loop via the common-wire that connects RIAA-signal-ground with player-signal-ground. If needed (preferred it is) a separate signal-ground and chassis-ground should also be created in the player, and then you will have the proposed 6-wire RIAA to player connection.
Old 19th January 2013, 04:23 PM   #1156
miepa is offline miepa  Austria
the bill of materials says
POWER RESISTOR 3W
for R27, R29 R104, R204
does this mean MOX Resistors or what is exactly meant by Power Resistor?
thanks.
Old 19th January 2013, 04:29 PM   #1157
FdW's Avatar
Paradise Builders
POWER RESISTOR 3W
thanks.
A resistor with a fixed value capable of dissipating 3 watts.
Any of these Resistors | Mouser (I do prefere metal film )
Old 19th January 2013, 04:42 PM   #1158
Old 19th January 2013, 05:46 PM   #1159
Banned
Correct if you have a player with a chassis
Mine and most budgets are double insulated (mains plug has only live and neutral conductors) as mentioned and body is made of MDF
So I only need to ground the arm
Old 19th January 2013, 05:52 PM   #1160
FdW's Avatar
Paradise Builders
And you are totaly correct In this case, go to a 5 wire connection.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 02:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
