Paradise Builders
Paradise Builders
Old 10th January 2013, 01:48 PM   #1021
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
Originally Posted by Bksabath View Post
Wuld one design new board for separate power suply and one for phono addressing thermals?
Only the regulator has to be as close as possible to the active circuits...unless it uses sense wires.
After a quick listen to the non-oscillating regulator i am pleased to note that the audible hiss has practically disappeared and the Paradise is indeed very quiet.
Sound is quite pleasant and if anything is not quite to my liking it is the spatial aspect - both sound stage width and depth. Not sure if that's the circuit's sonic signature or the pcb groundplane...
Old 10th January 2013, 01:59 PM   #1022
PMA is offline PMA  Europe
PMA's Avatar
Paradise Builders
That's perfect and it should be so, as HF oscillations are usually audible as increase of hum or hiss or both.
Regarding your LF fluctuations, do you have your boards in shielded boxes?
Old 10th January 2013, 02:19 PM   #1023
analog_sa's Avatar
Not at the moment but will be very easy to have them boxed. Why would the shielding matter? Just blowing on the input transistors generates tens of millivolts at output. Will definitely experiment some more with speeding the servo up.
Old 10th January 2013, 02:35 PM   #1024
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Just box the input transistors (use a matchbox (for testing) or something like that). If this works, then use a small copper box (so it can dissipate some heat).
Old 10th January 2013, 02:47 PM   #1025
analog_sa's Avatar
Good idea, thanks
Old 10th January 2013, 11:48 PM   #1026
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise Builders
I seem to have a bit of a gain mismatch, despite all the components being ruthlessly matched, input transistors better than 5%, current mirrors better than 10% and output from the shunts are all matched within .1v
Any suggestions?
Paradise Pre-reg PSU PCBs
Old 11th January 2013, 01:26 AM   #1027
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That has being discussed before, you can match the gain by adjusting the emitter resistors of the input stage. How much is it ? 1dB ?
Old 11th January 2013, 06:30 AM   #1028
'about 1bd?' - it's about 10cm off to the left from my central seated position, so yes. I'll push a reference level through it today and scope the output.
Old 11th January 2013, 06:45 AM   #1029
analog_sa's Avatar
AC voltmeter will be more useful. Just make sure you stay at a reasonably low frequency. Unless you have actual measurements it is impossible to know if the channel imbalance is not due to cartridge, antiskating compensation or something else entirely. As Joachim explained earlier on you can then reduce degeneration from the emitter resistors of the weaker channel by soldering resistors in parallel.
Old 11th January 2013, 07:16 AM   #1030
;-) it's not the deck set-up, that is perfectly in balance on all the various stages that pass through my doors. It swaps channels when i swap the outputs from the boards but not when i swap the tonearm leads going into the boards.
I'll create some files on my pc and run them through. I should test the RIAA curves as well and see how close they match.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 20th May 2018 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
