Paradise Builders - Page 102 - diyAudio
Old 10th January 2013, 12:27 PM   #1011
Waly is offline Waly  Uzbekistan
Waly's Avatar
Originally Posted by PMA View Post
This we can see from Bode plots.
FWIW, those are not Bode plots.
Old 10th January 2013, 12:37 PM   #1012
PMA is offline PMA  Europe
PMA's Avatar
They ARE the Bode plots. The post (985) was here:
Paradise Builders
Your posts like this are completely useless, you are bringing no insight here. Similar as in case of your not understanding how the DC servo works.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 10th January 2013, 12:41 PM   #1013
analog_sa's Avatar
Get used with it, or AC couple the pre.
Sorry, not sure what your link points to.
AC coupling is a possibility, maybe even a must in case this is followed with a dc coupled line stage. It does feel a bit of a waste to have a servo though. In order to minimise coupling cap size i may consider providing a bias resistor ahead of the output buffer and including the cap between the riaa and buffer. That is, unless someone comes up with a smarter suggestion. In any case, even without the servo and going for ac coupling it will be useful to achieve good thermal coupling between the input devices.
Old 10th January 2013, 12:47 PM   #1014
FdW is offline FdW  Netherlands
FdW's Avatar
Are you sure .....
Normally the shielding box should be connected in one point with board ground, reference 0V or something like this. In case you leave metal box floating, it will NOT serve as a Faraday cage. It will act as an antenna and it will couple the EMI noise received on its surface thru coupling capacitance (just geometrically defined) into the circuit board (do not forget you have the wires going IN and OUT of the box). If you connect the box with board reference ground, then it WILL act as a Faraday shield.
I'm sure, a metal box, grounded or not, will alwais work as a cage of Faraday. No radiation can escape (a true) cage of Faraday.
Faraday cage - Wikipedia, the free encyclopedia
Old 10th January 2013, 12:52 PM   #1015
FdW's Avatar
Are you sure .....
In the box-in-a-box-in-a-box case the outer box should be chassis ground (and (at the star point) be connected (using a DDRC I would suggest) connected to the signal ground).
Old 10th January 2013, 12:55 PM   #1016
FdW's Avatar
Are you sure .....
And (last point) if it is an inner box there is nothing to receive (for the antenna, from the outside any way). On the other hand, an gage of Faraday could be looked upon as a shorted antenna. In the proposed case, the antenna would 'receive' all radiation that is in the box, and then short it into oblivion (actually heat ) as long as it is not bouncing around (Hermann von Helmholtz http://en.wikipedia.org/wiki/Helmholtz).
Old 10th January 2013, 01:02 PM   #1017
buzzforb's Avatar
Originally Posted by hesener View Post
Stay tuned for an update of the assembly guide, then
Thanks Hessener. It is greatly aprreciated.
...Shape the sound , Man!
Old 10th January 2013, 01:06 PM   #1018
Banned
Originally Posted by FdW View Post
Also, it is a good indication for the need to put the prereg in a separate metal enclosure The question is, how far are you (the builder) prepared to go .
Good question but I now can say that MyParadise R2 is prety quiet
Good (realy good) board design prety good Power suply and regulators
It does not oscillate as far as I can tell and the litle bit of ofsset on the output do not seem to bother mine or another pair of speakers I have eard
So tick box for trafo and box Phonos tick main filter supressor and tick for buss of star on earth.
And use Steinless Stell 304 and a further jacket of cooper but is it realy necessary as it performs quite well just sitting on a carpet
Wuld one design new board for separate power suply and one for phono addressing thermals?
Old 10th January 2013, 01:32 PM   #1019
Waly's Avatar
Man, you are one nervous guy! And I though I clarified the servo problem (and also the input bias current red herring) .
They are not Bode plots, at least not in the sense required for a complete circuit stability analysis. A simple plot of the crcuit transfer function vs. frequency is pretty much useless for analyzing a circuit stability.
But perhaps I am wrong, so please specify the Y units on the loop gain plot and the method used to determine the gain and phase plots, also the feedback loop(s) you are analyzing. Otherwise, everything is mirrors and smoke.
Old 10th January 2013, 01:40 PM   #1020
Waly's Avatar
You almost got it. In a very high gain servo controlled, DC coupled amp, noise fluctuations are visible at the output, that's unavoidable, happens even in proffessional metrology equipment. Input noise has a quickly increasing power with decreasing frequency, so .1Hz fluctuations have a much larger amplitude than, say, 10Hz. If you get 200mV, that's a lot though, could be another additional cause as well (like a bad contact, or a joint thermoelectric contact pile).
Somewhere in the audio chain, there is a high pass filter removing those fluctuations. If you want to control these, just add a 5Hz (or even less) pole somewhere.
Paradise phono stage hesener Group Buys 1375 19th September 2016 02:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright 1999-2017 diyAudio
