My version of an Ultrasonic Record Cleaner My version of an Ultrasonic Record Cleaner - Page 24 - diyAudio
Old 30th December 2012, 11:26 PM   #231
cbachalo is offline cbachalo  Canada
Default 80KHz German Elmasonic version...
Thanks BB,
I had the same design goal ie. no damage to ultrasonic machine. My record cleaner attachment fits snugly in place around the lip of the stock cleaner and lifts off for storage.
1.5" aluminum angle would give you room for more records. 4 records on my machine with 2" angle and the Vinyl Stack spacers is a very tight fit.
I have been recording pre and post cleaning so i can do quick A/B comparison afterward. Will post some soon.
CB
Originally Posted by bbftx View Post
Hi CB, Your setup looks great! Nice metal work!
My version 2 setup, which is almost complete, is similar in that it uses aluminum angle stock to create a removable frame. I received a number of messages inquiring about a setup that didn't require one to drill holes in the ultrasonic cleaner. I am using 1.5" aluminum angle stock, along with 5/8" channel stock that fits over the lip of the cleaner and helps hold the assembly in place. I am also using rivets, like you, as they are excellent for holding thin metal sheet together. [One of my favorite tools is a hydraulic air rivet tool that works very well and makes riveting a breeze!]
Pictures to follow once I complete the last details.
I have designed both a fixed motor housing setup that one could use with quick-connect spindles, and a movable arm setup on my revised design. I will be going with the modified arm setup for my use. For the pivot, I am using a bracket used for legs on a folding table leg. (See attached photo.) These are very rugged brackets, which easily support the loaded weight of the arm. The brackets also lock in both the upright position and with the arm down. This results in a setup that is a little sturdier than my original PVC pipe based design.
I have been considering posting "before and after" recordings with URC-cleaned LPs. I have the A/D conversion hardware and software to do this, just haven't gotten around to it yet!
B B
Old 30th December 2012, 11:47 PM   #232
bbftx is offline bbftx  United States
bbftx's Avatar
Default Loading
Originally Posted by cbachalo View Post
Thanks BB,
CB
Hi CB,
My 1.5" aluminum angle doesn't project too far over the lip of the machine, since I'm attaching it to the channel stock that fits over the lip of the cleaning machine.
Regardless, I don't believe you want to try to put more than 4 records in the bath at one time. I'm limiting my setup to 3 at a time. Here is a link to an earlier post I made in this thread about how much surface area you want to try to clean at one time.
URC Loading and Spacing
B B
Old 2nd January 2013, 07:24 AM   #233
Ishmail is offline Ishmail
Default Design for cleaning + rinsing
Happy new year, everyone.
The polycarbonate parts I ordered in October finally came in, so here are pics of my design. It's complete save for 6 solder connections left undone when my cheapo iron died --- so please excuse the alligator clips and missing enclosure on the electronics. One goal was to make the rotisserie part lift off as a unit with the records in place for easy transfer between the USC machine and two rinse tanks. This led to some similarities with CB's and BB's designs with removable frames, although the implementation is different.
The main components are: 1/2" polycarbonate deck, stationary-mount 12 VDC motor (rear), spindle assembly [adjustable-torque friction hinge, a 1/4"-thick rectangular plate with two roller-bearing pillow blocs, the spindle, and LP spacers with collars], a PWM speed controller, ON-OFF-ON waterproof rocker switch (front right), 12V power jack (right rear), and nitrile foam rubber attachment strips (visible gripping tank top through deck). The friction hinge and rectangular plate are functionally equivalent to BB's PVC pipe assembly. This one normally retails for about $20 but I found it available for $2. When rocked forward, the switch bypasses the speed controller and the motor turns at close to its nominal speed of 3 RPM, a good speed for the first rinse. When rocked backward, the PWM provides continuously variable speed down to a minimum in the range of 15-20 RPH allowing for slower speeds for the cleaning and final rinse stages.
The friction hinge maintains the records in any position, shown here rotating from vertical for loading/unloading LPs, to inclined for drip-dry, to horizontal for rotisserie. The spindle cantilevers from the dual pillow blocks, the motor only provides torque through the flex coupling.
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
The spindle slides a bit more than an inch in the horizontal position. This provides for disengaging the spindle from the coupling and just enough clearance to avoid interference between the LPs and the coupling and deck surface. The fit in the friction hinge and pillow blocks is sufficient that the spindle reliably engages the coupling when it slides into position --- no fiddling needed. I have thumb screws on order to replace the provided coupling and collar clamp screws for better ease of use.
I cut the foam rubber strips from the same knee-saver mat I used for my spacers. They're shaped to grip the top of the cleaning machine tank and the tops of similarly shaped rinse tanks. There is a groove cut in the rear strip that grips the tank lip to prevent the deck from tipping off the tank when the spindle is in the vertical loading position. In other positions, the center of gravity falls between the two support strips, so there's no risk of tipping. The foam rubber strips also align the mechanism with the tank and provide quieter operation during ultrasonic cleaning. They also allow the deck and LPs to be easily lifted and repositioned to either rinse tank within a few seconds. Rinsing is convenient and only adds a few minutes to the process. As noted in a previous post, the rinse tanks are standard polycarbonate 1/3 size food pans (with lids for storage) readily available from restaurant supply stores or websites.
I grew tired of readjusting the position of my pump, filter and tubing, so I designed this simple stand made of ABS with 12V jack and power switch. The filter housing attaches to the stand with a velcro patch. Vinyl feet reduce noise and prevent the assembly from sliding around.
I'll post more later about my experience using Tergazyme (Alconox + protease) cleaner at full strength. This definitely requires rinsing, but it's well worth consideration based on performance IMO. Some of the newer designs posted here can probably be adapted for rinsing with very little effort.
Old 2nd January 2013, 12:23 PM   #234
Default Nice job Ishmail!
Like the 3 angle design for your spindle. Loading and unloading the spindle is cumbersome with the spindle removed since one hand is holding the spindle which only leaves you one hand to load the records. Can you post a closeup picture of your hinge design. How do the records clear the other side of the cleaner when they are swiveled up and down?
Anyone figured out an automatic dryer yet? For now I am just air drying the records while on the spindle with a blow dryer.
Old 2nd January 2013, 07:06 PM   #235
Default Details
Thanks CB.
Here's a detail view of the friction hinge/pillow block assembly:
The stationary part of the hinge sits on a piece cut from the same 1/4" stock as the moveable, rectangular "arm," so the arm lies perfectly flat on the deck in its horizontal position. Coincidentally, this puts the spindle axis at precisely the same elevation as the axes of the motor spindle and flex coupling. I'd planned to shim as needed, but it wasn't necessary. The black screw in the middle adjusts the torque resistance of the friction hinge. This is the same type device as those used to support laptop displays, but this one is marketed, among other uses, to support hatch covers in open positions for ventilation on yachts. It's capacity is much greater than needed in this application, but the adjustable resistance is important. Look for the E6 adjustable torque model from Southco for more information.
Here is a view showing the critical clearance between the top LP and the coupling during rotation to/from the horizontal configuration. It's tight but reliable in this design. The cutout in the deck avoids any interference there. I'm using fairly wide spacing, ~ 1-3/16", between LP surfaces to promote good penetration of the ultrasound wave field. Tighter spacing would make this clearance easier. I glued metal electrical enclosure covers with gaskets to both sides of my foam spacers to create a very stiff and durable sandwich plate structure (see second photo below). I did this primarily to add stiffness, because I thought the flexibility of the foam spacers alone might be a contributing factor to the warping problems I was having earlier. It also provides more generous spacing between the LPs.
For batches of 3 LPs or fewer, its convenient to leave the spindle mounted in the pillow blocks while loading, cleaning, drying and unloading the LPs. For larger batches, it's worth using 2 or 3 spindles as BB recommended earlier, to pipeline loading, cleaning and drying (see second spindle in preceding photo). In this case, it's easy to slip the spindles in or out of the pillow blocks, especially in the vertical position. Just pull gently along the spindle axis. This is best done with one hand for demounting, possibly using the other hand to align the spindle with the top bearing when mounting.
For drying, one possibility I haven't tested yet is to move the assembly onto an empty tank to rotate the LPs while a fan blows on them. I'll report back after I give this a try. One advantage of BB's first design, where the motor is mounted on the moveable arm, is that it's easy to keep the records rotating for drying after they're removed from the bath.
So far, however, I've been using the final rinse as the first step in drying. It's counterintuitive, but true --- you can dry a record by dipping it in water. If all of the surfactant is removed in the first rinse stage, we're left with clean vinyl which is hydrophobic. Using garden variety distilled water in the second rinse, I find that nearly all the water falls off the LP if the rotation and final removal from the bath are sufficiently slow. For LPs in good condition, with few scratches and scuffs, I find no beads left above the grooves on the record surface and air drying without a fan only takes a few minutes. Records in rougher condition tend to retain a few beads, and these take much longer to dry, possibly due to the increased surface tension of distilled water. The beads can be wicked away with a clean bit of tissue, or you can just wait it out.
Old 2nd January 2013, 08:41 PM   #236
rickmcinnis is offline rickmcinnis  United States
Default Not a FAN!!!
Unless you are going to make a miniature clean room (and based upon what I see with your US implementation it just might be in order!) I think a fan would not be a good idea.
Sure there is plenty of stuff floating in the air when you leave the LPs to air dry but concentrating with a fan ...?
Ishmail, what you have done is impressive and impressive looking but you must forgive me in thinking you might have gone too far for what is simply an easy way to clean records.
You should go into the hyper high end turntable business!
Rick McInnis
Old 2nd January 2013, 11:32 PM   #237
Default Different strokes
Hey, Rick. Thanks for your comment; you might well be right about fans. They often do more harm than good by kicking up settled dust, as people with allergies who have tried fan-driven air filters can attest.
I think all of the designs in this thread are better ways to clean records, not just easier. I suspect they all perform better than the Audio Desk product which seems to have placed greatest emphasis on convenience (defined by short total cycle time, full automation, no heating, etc.) and deemphasized cost as a consideration. Nonetheless, the Audio Desk cleaner still performs better than vacuum cleaning methods --- or so say the reviews --- and might well be a good design solution according to their business plan.
Design always involves trade-offs between cost, ease of construction, ease of use, etc. There's not one best solution; it depends on one's personal or business goals, the tools, materials and skills you have available and so forth. For example, I see the VW bug and some of the more expensive cars as equally great solutions to different design problems. BB's original design, including the decision to skip rinsing, is a great solution for people looking for low cost and simplicity in implementation and use. On the other hand, a $2 pre-engineered friction hinge is also a pretty good solution worth considering by any standard.
Sound quality is my highest priority, ease of use second, and appearance third. When they are not in conflict, as is often the case, I go for all three. I'm cost sensitive, but willing to invest a little more (not very much in this design) to improve a machine I intend to use often over a long period. Another design goal was to build a platform for experimenting with rinsing and different rotation speeds. Depending on what I learn, it's likely the design can be simplified, say by eliminating the speed controller if I settle on specific settings. If I find that rinsing isn't worth it, the machine would still work well for cleaning alone.
I enjoy design in its own right, both the product and the process. The many hours I spent researching, designing and building this project were pure fun. Others might prefer to borrow a design and get to something that works well quickly without all the fuss --- entirely reasonable and BB has done a great service for this group. I'm not at all surprised or offended if my goals don't match everyone else's. If a few readers find aspects of my design useful or just interesting, so much the better. If not, what can I say?
Old 5th January 2013, 03:13 PM   #238
Default Stand for loading spindle
Here's a stand for loading/unloading. It uses vertical orientation which I find most convenient. Be sure to finish your drink before using!
Old 5th January 2013, 03:22 PM   #239
Default Brilliant!
Old 7th January 2013, 02:44 AM   #240
bbftx's Avatar
Default BB's Rotating Arm URC, Version 2
Here is version 2 of my Ultrasonic Record Cleaner (URC) setup. Its operation is similar to my original rotating arm system, which was based on PVC pipe fittings mounted directly to the casing of the ultrasonic cleaning machine.
But this version is stouter---- made from aluminum and steel ---- and the removable frame sits on the same Sonix IV ultrasonic tank without the need for any screw holes drilled into the machine.
I'm using the same 5 rev per hour Synchron motor from Herbach & Rademan, mounted in an electrical box. The steel arm is mounted on an inexpensive, but nifty little folding table leg hinge that locks in both the upright and down position. It's very sturdy and gives me plenty of clearance over the side of the tank in the upright position.
As before, I'm using 9/32" drill rod (to match the size of a standard record player spindle) passing through a sintered bronze flanged bearing in a sintered aluminum pillow block.
The arm sits atop a frame made of 1.5" aluminum angle stock. The frame also incorporates 5/8" u-channel stock that fits nicely over the lip on the sides of the cleaner. Felt has been added to the inside of the channel stock to minimize vibrations. I took the photos of the underside before this was added so you could get an idea of how the frame is riveted together. On the side and end of the frame opposite the hinged arm, I've added a fair bit of steel as counterweighting. This balances the entire frame and allows it to sit very, very firmly in position whether the arm is raised or lowered.
The metal version took a bit more time and effort to build, but I prefer the rigidity and solid feel of this setup vs. my PVC version. My cleaning solution filter and pump will work the same way with this setup.
I made a 45 second video showing how quickly the frame and arm unit can be placed on the cleaning machine and loaded with records. Here is the link:
Video: Setting up BB's Rotating Arm URC Version 2
B B
My version of an Ultrasonic Record CleanerHide this!Advertise here!
I made myself a record cleaner Sclalars Analogue Source 231 20th February 2017 05:01 PM
My DIY record cleaner. mattjk Analogue Source 105 9th March 2016 04:05 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 03:28 AM
diy ultrasonic cleaner, not using bought unit 3GGG Analogue Source 0 10th January 2011 09:28 AM
Ultrasonic Parts cleaner... DIY??? pk386 Everything Else 1 10th May 2004 06:55 PM
Copyright ©1999-2017 diyAudio
