My version of an Ultrasonic Record Cleaner
Old 25th July 2018, 12:51 PM   #1961
Packgrog is offline Packgrog  United States
Avoid paper as a wipe, as that will cause more scratches. Along those lines even the cleanest of albums tend to have more noise at the beginning of each side since that seems to be where scuffing from the sleeve happens most.
Old 25th July 2018, 04:12 PM   #1962
bbftx is offline bbftx  United States
bbftx's Avatar
Originally Posted by philliplederer View Post
Thanks for the advice. I did change the water after my initial posting and although not apparent from a tank view, the dumped water was really filthy.
Hi Phillip,
Did you wash the tank itself with soap and water? A lot of crap can get deposited on the walls of an ultrasonic tank, especially a used one like you procured. If you haven't already done so, clean it well with soap and or stainless steel cleaner, and rinse thoroughly.
B B
Old 2nd August 2018, 04:24 PM   #1963
BendBound is offline BendBound
Since I last posted I've acquired an USC kit for the sole purpose of cleaning my vinyl record collection. This note deals only with filtering and water quality, given the interest in the last few posts. Later on I will mention some issues I encountered with a USC machine made overseas. However, I recommend that everyone read the latest post (#3) on The Vinyl Press by Tima, on updates to his system and his routine for cleaning vinyl records using a USC.
My system for all intents and purposes follows Tima's. But I have some different equipment from his system and I benefited a month or so ago from a recommendation he made on filtering. So I wanted to touch on these in this note.
My system actively filters the USC cleaning solution of 10 liters of distilled water, 312 ml IPA (99%) and 13 ml of Ilfotol wetting agent. I keep the IPA to about 3% of total solution and monitor that volume using a specific gravity bulb gauge (beer making equipment). My routine is nearly exactly what Tima recommends, but with a Vinyl Stack (4 lps at a time) stand. The Vinyl Stack has the ability to rotate the lps at different speeds, but the slowest is still faster than what Tima uses.
About the filtering: from the USC tank I connect to an Italian made Sicce Syncra Silent 0.5 non-submersible aquarium pump. This very quite small hand-sized pump moves the solution at ~170 gallons per minute. I purchased this pump at a local aquarium shop, on sale actually, for $21. This workhouse is fantastic, no leaks, and nearly silent.
After the pump, the solution enters a Pentek slimline 10" filter housing with its clear plastic "tank" bottom. I got this unit with 3/8" inlet and outlet fittings. The filter I use was recommended by Tima; the 0.35 micron Flow Max FM-0.35-975 2-1/2" x 9-3/4" pleated filter.
I just recently cleaned 48 records in one day. As Tima reports, the solution is filtered very well and remains remarkably clear. His article shows ppm concentrations, extremely low numbers as he measured. After cleaning nearly 50 lps, I opened the filter housing to inspect the pleated filter and the water remaining in the Pentek tank. After shaking it up a bit to put into solution any dirt, the color of the liquid turned cloudy, like a well-known wheat beer, if you know what I mean. I dumped the yellowish-gray spoil, removed the filter to wash it. Technically, Flow Max specifications show that this very fine (0.35) micron filter is not washable, but I did wash it with the force of water from a tap. I washed it inside and out, and put it back in the tank to swish it back and forth to dislodge and remove as much filtered debris as possible. In the filter pleats I did observe some very small dark bits, presumably particles removed by the cleaning process. Unfortunately, I was not able to remove all debris in this washing routine. Then I rinsed the Pentek tank and the Flow Max filter with distilled water and put the kit back together.
Based on this experience, I definitely recommend using a filter for USC tank solutions. It is easy to find the parts, it does not cost that much (~$75, the full price of the Sicce pump is $42), and it is incredibly effective. Further, filtering removes particles that otherwise will damage an lp if maintained in the USC tank during operation. Consider inspecting the filter after say 25 to 30 lp cleanings. Dump the filter tank contents and rinse off the filter itself. Then top up the solution and begin again. After treating 75 to 100 lps, I would replace all of the solution in the system, start over with fresh distilled water, IPA, and Ilfotol.
I'll add that I air dry the 4 lps that are cleaned at a time. It takes about 20 minutes. I see absolutely no residue on the lps, particularly on the slice that is wet when I pull the kit from the USC tank. They are really clean. And they sound phenomenal.
At any rate, read Tima's great update as published in Bill Hart's The Vinyl Press.
Old 2nd August 2018, 05:05 PM   #1964
Edit: The Sicce pump operates at ~170 gallons per hour. Not per minute as written above. I was not able to edit the original post due to time limits. Excuse the error.
Old 16th August 2018, 11:22 PM   #1965
waldemark is offline waldemark
Default The Art of Attachment
Hello, all!
I became interested in USM cleaning about 5 years ago, left for Indonesia (doing NGO work and teaching), and am now picking up that interest again. I found this discussion thread - what a gold mine! Am working through, now on p. 35.
Unfortunately, many of the old attachments are gone, including BB's part lists. If some kind soul could "sticky" a post with durable attachments to the beginning of this thread I'm sure that would be of immense service to many. Alternately, if anyone has saved that information and would pass it on, either by reposting with a new attachment or PM'ing me, that would be terrific.
I hope to post and contribute to the conversation here soon.
Be well,
waldemar
Old Yesterday, 06:11 AM   #1966
bbftx's Avatar
Hi Waldemar,
It's unfortunate that many of the attachments were stripped. I think that happened a few months back when one of the admins mistakenly deleted the entire thread instead of a single violating message. When restored, the thread seemed to be missing attachments.
I reposted the version 2 and version 3 parts list here:
BB's Part Lists for v2 and v3
Some of the parts aren't available anymore, and there've been some alternative pumps found in the mean time too --- there are lots of options!
B B
Old Yesterday, 09:05 AM   #1967
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by bbftx View Post
Hi Waldemar,
B B
Your link doesn't work for me.
Old Yesterday, 11:48 AM   #1968
Hi Merlin,
Not sure what's up with the link, but I was able to track back to p. 191 of the thread (My version of an Ultrasonic Record Cleaner) and there are actually a couple of posts where BB kindly reposted things for us.
Hope this helps,
Waldemar
Old Yesterday, 11:52 AM   #1969
bbftx's Avatar
Letís try the link again for version 2 and version 3 parts lists
B Bís URC Parts Lists v2 and v3.
Cheers, BB
My version of an Ultrasonic Record CleanerHide this!Advertise here!
Ultrasonic Record Cleaner surfactant multirock Analogue Source 6 9th October 2017 10:30 PM
DIY Ultrasonic Record Cleaner - What Frequency to Use? DougB59 Analogue Source 4 9th July 2015 09:47 AM
ultrasonic record cleaner help j2d2 Everything Else 2 1st April 2015 09:42 PM
Looking to build ultrasonic record cleaner ErikPSmith Introductions 1 12th January 2014 06:18 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 03:28 AM
