My version of an Ultrasonic Record Cleaner
Old 6th December 2017, 01:56 AM   #1811
3brats is offline 3brats
Originally Posted by bbftx View Post
I've had a VPI HW-17 record cleaner for some time, but have always wondered if there was a way that could deliver better cleaning results along with less contact with the vinyl . So, after reading threads here and elsewhere about using ultrasonic cleaners to get the dirt off of vinyl, I thought I'd rig up my own unit.
I started with an ultrasonic cleaner that uses 60 KHz transducers. It was a little harder to find and a little more expensive than the typical 40KHz Chinese-made units, but the higher frequencies theoretically do a better job at cleaning the very small grooves of a record and there is less risk of damaging the vinyl from the cavitation. Those two points are a big advantage of 60khz units over 40khz units.
To rotate the records, I wanted to minimize motion in the cleaning solution. My target was a 4 minute cleaning time for the vinyl surface. Given that about 1/3 of the record is submerged in the solution at any moment, the math told me to find a 5 revolution per HOUR synchronous motor. Synchron makes such motors in almost any rph or rpm you could want. The 5rph motor yields a 12 minute rotation time. My plan is 1 rotation = 1 cleaning cycle.
I fashioned a spindle out of 9/32 W1 drill rod. It was was easy to machine a 1/8" diameter hole in one end of the spindle on my lathe to fit over the motor shaft (1/8" diameter).
The motor and shaft are mounted in place using an electrical connector box and conduit. The arm is mounted to the ultrasonic unit using L-brackets and pipe straps. The setup allows the motor and spindle assembly to be rotated up to load records, and then rotated down into the bath.
My spacers are 4" diameter, 1/2" thick cork rounds. [Oct 2012 note: I have since found different spacers, which are much better: I've ordered these from the UK: 110mm by 105mm tapered cork stoppers - they cover the record label completely and very little of the lead out groove. They are just a touch over 1" thick, which is optimal spacing.
No.37 Natural Cork Stopper 110mm from Just Cork No. 37 Large]
[Dec 2012 Note: I added a sintered bronze bearing and a bearing housing to support the weight of the spindle, records and spacers, and eliminate the bending moment on the motor shaft.]
I'll report back after I clean and play some vinyl. My first batches will use distilled water and isopropyl alcohol at about 7 to 1 [Sep 2012 note: I've since gone to a much lower concentration of isopropyl, about 50 to 1] , with a few drops of Kodak PhotoFlo. This solution, combined with the very slow rotation, will allow the liquid to drain off the vinyl surface very easily.
The cleaner can still be used for any items you'd normally put in an ultrasonic unit. It does a great job on some fairly intricate gold jewelry I've cleaned.
Photos below. Questions and comments welcome.
[Feb 2013 Note: I have built a second, sturdier design using a metal frame and hinge assembly that fits over the top of the Ultrasonic cleaner. Here is a direct link to the description later in this thread:
Version 2 of BB's URC
And here's a direct link to the post with the parts list for Version 2:
BB's URC Version 2 Parts List ]
Feb 2015 Note: I've built a 3rd version, designed to be assembled with fewer tools and be more adaptable to different cleaners. Description, pics, and parts list for Version 3 start here:
BB's URC Version 3
Happy building.
BB
Attachment 297136Attachment 297137Attachment 297139Attachment 297140
Attachment 297141Attachment 297142
Hello, first time posting. Could you suggest an alternative to the pillow block bearing/ housing for version 3? SDP currently doesn’t have the bearing in stock, and my work schedule makes it tough to get to a machinist to have the bearings pressed into the housing. Having a hard time locating a pre-pressed unit online. Any help would be greatly appreciated!
Old 6th December 2017, 02:43 AM   #1812
bbftx is offline bbftx  United States
bbftx's Avatar
Hi 3brats,
(Is that username a nod to number of children by chance?)
This is not a demanding application for a bearing, so almost anything you can slap together to support the output shaft connection would be fine. One option to eliminate any machining or press fitting would be to just go with more common ¼" sized components to mate with the motor output shaft, or go to a slightly oversized 5/16" ID bearing in a pillow block if you're using a 9/32 arrangement. I just used 9/32" because I had extras from my prior builds and I wanted to show that it was possible to assemble a true-to-turntable-spindle-dimensions 9/32" setup.
Does that help?
B B
Old 7th December 2017, 01:37 AM   #1813
Hi 3brats,
Does that help?
B B
Yes, that's a big help. I've already ordered the 9/32" spear shafts, so I'll go with the 5/8. My technical skills and knowledge are very limited, so I appreciate the advice. Also, I went with the HR motor. What length should my D-shaft be? (And yes, my moniker was inspired by my children, who now have brats of their own.)
Old 8th December 2017, 02:18 AM   #1814
bbftx's Avatar
3Brats,
If you're asking about the shaft on the H&R synchron motor, it should be ⅛" diameter, ⅜" long.
B B
Old 12th December 2017, 01:16 AM   #1815
3Brats,
B B
I received my motor today, and I’m still confused. According to the parts list, I’ll need a 1/4” to 1/4” coupler. But since the motor shaft is 3/8”, I’m thinking I need a 3/8” to 1/4” coupler. Is this the case? Thanks again for your help.
Old 12th December 2017, 04:06 AM   #1816
bbftx's Avatar
3 brats,
I used an All-Electronics motor in version 3. It had a ¼" diameter output shaft. The H&R motor should have a ⅛" diameter shaft, ⅜" of an inch long. Parts have to be adjusted according to your specific build.
BB
Old 12th December 2017, 07:04 AM   #1817
lexx21 is offline lexx21  United States
Default 1 micron filter and triton x100
I had a thought last night (always a dangerous thing)....
I picked up the parts for the filter system that one of the posters had built. It uses a 1 micron drop in filter. My question is, would that be too small to allow the triton chemical to pass through. It probably isn't but thought that I would ask anyway.
I'm in the process of putting together my US cleaner... I just have to wait for the coupling adapter... ugh.
Old 12th December 2017, 10:53 AM   #1818
bbftx's Avatar
Lexx,
In a water solution, Triton x-100 molecules travel in clumps called micelles. The typical micelle of Triton molecules will be two orders of magnitude smaller than a 1 micron filter pore diameter. It would be the equivalent of a 1 inch bug walking through a 100 inch doorway. So, I don't think a 1 micron filter will remove Triton from the solution.
B B
Old 12th December 2017, 10:55 AM   #1819
Shaun is offline Shaun  South Africa
Shaun's Avatar
LOL! Loving the imagery!
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 12th December 2017, 03:25 PM   #1820
I didnt think that it would be an issue, but wanted to be sure.
My version of an Ultrasonic Record CleanerHide this!Advertise here!
I made myself a record cleaner Sclalars Analogue Source 231 20th February 2017 06:01 PM
My DIY record cleaner. mattjk Analogue Source 105 9th March 2016 05:05 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 04:28 AM
diy ultrasonic cleaner, not using bought unit 3GGG Analogue Source 0 10th January 2011 10:28 AM
Ultrasonic Parts cleaner... DIY??? pk386 Everything Else 1 10th May 2004 07:55 PM
