My version of an Ultrasonic Record Cleaner
Old 2nd October 2017, 02:55 AM   #1791
bbftx is offline bbftx  United States
bbftx's Avatar
Sundodger,
I just used a steel part from my junk parts bin.
Here are some actual parts options to consider on Amazon:
1. Jeremywell 25BS11-1/4'' Bore 11 Tooth Sprocket
2. Martin Roller Chain Sprocket, Reboreable, Type B Hub, Single Strand, 25 Chain Size, 0.25" Pitch, 14 Teeth, 0.25" Bore Dia., 1.246" OD,
Good luck,
B B
Originally Posted by Sundodger View Post
Hello
I have all of my parts, except the 1/4" id X 1.25" gear for the magnet and shaft to connect to. Does anyone have a part number and source for this part?
Sundodger
Old 3rd October 2017, 01:13 AM   #1792
dmkbox is offline dmkbox  Russian Federation
Hi. Can someone know easy solution to build record support gear? I have low speed motor. But I cannot access to diy materials and machinery. Need something easy to find.
Maybe china-made solutions?
I already have 6l bath.
Old 7th October 2017, 06:54 PM   #1793
japtim is offline japtim  United Kingdom
My solution was an eBay "disco ball" motor screwed to a wooden L shaped bracket
The bath 10ltr stands on the bottom piece of wood with the L up the side of the tank with the motor above and to the side of the tank
A machined spindle just slips over the motor spindle and the record is secured by slip on silicon tube to supply the drive
It works very well with a DIY mix of alcohol/ water/photo release agent at 30degrees
Old 2nd November 2017, 06:48 PM   #1794
Vladimir1970 is offline Vladimir1970  Russian Federation
Greetings to the distinguished community!
I want to express my gratitude to those who actively participate in the topic of ultrasonic washers. I read a lot on this topic, including this topic, and as a result we made a project for Russian music lovers, which is 2-4 times cheaper than imported analogues. Once again, thank you all!
Here is a photo and video of what we got:
YouTube
YouTube
Old 2nd November 2017, 08:12 PM   #1795
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Just beautiful !
My next project..
David
Old 2nd November 2017, 11:29 PM   #1796
Yes that is a great looking bit of kit
If it works half as well as it looks...it will be great!!
Old 3rd November 2017, 12:15 AM   #1797
lexx21 is offline lexx21  United States
Just ordered a 40khz 6L cleaner, .6rpm motor, 7mm brass rod, other parts and pieces. The only thing left to order is the delrin to make the mounts from. Sort of emulating the design from an Aussie fellow on youtube. Hopefully I will have it all built out by the end of the month.
Old 3rd November 2017, 02:16 AM   #1798
I have had excellent results from ultrasonic cleaning
Records really do come out spotless and a de-staticted too
I even tried leaving a record in the bath (not rotating) for an hour so nearly half was cleaned and the rest not
This was to see if long term exposure would damage the vinyl...when I played it I could tell no difference in sound quality as the record rotated.
Old 3rd November 2017, 08:29 AM   #1799
njjano is offline njjano  Italy
Beautiful product, congrats Vladimir!
Old 11th November 2017, 12:43 AM   #1800
How much triton x100 are you using in your us cleaners? Just a few drops?
My version of an Ultrasonic Record CleanerHide this!Advertise here!
Ultrasonic Record Cleaner surfactant multirock Analogue Source 6 9th October 2017 10:30 PM
DIY Ultrasonic Record Cleaner - What Frequency to Use? DougB59 Analogue Source 4 9th July 2015 09:47 AM
ultrasonic record cleaner help j2d2 Everything Else 2 1st April 2015 09:42 PM
Looking to build ultrasonic record cleaner ErikPSmith Introductions 1 12th January 2014 06:18 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 03:28 AM
