My version of an Ultrasonic Record Cleaner - Page 51 - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Wiki Blogs Register Donations FAQ Calendar Community
Old 19th January 2014, 10:30 AM   #501
dimkasta's Avatar
Originally Posted by Fukinagashi View Post
Mine comes from the UK.
I just ordered the electronic version....
Let s hope we won t have any surprises...
Second harmonic and wine for everyone...
Old 19th January 2014, 12:47 PM   #502
Okay, you got me, I am a total convert to ultrasonic cleaning. Sonix IV 60Khz machine with a 4RPH Synchron motor. Using distilled water, photo-flo, and isopropl alcohol mixture as suggested. Temp at 100-110 degrees. I have the parts to build the VIP clone, but now see that it would be a step backwards.
Surface noise is greatly reduced, and without using all the audiophile jargon, It just plain sounds better. I will post pictures of the mock-up later, but I'm pretty sure I am going to recess it into the countertop for a cleaner look. Thanks to BB and everyone else for posting all your efforts. Great job guys!
Old 20th January 2014, 09:01 AM   #503
TX for the synthesis. Don't want to be pedantic but it is important to say that 100-110 degrees is to be meant Farenheit (would not someone to boil records indeed )
Could anyone list possible suppliers for a 4-6 RPH motor in Europe?
Old 20th January 2014, 09:11 AM   #504
dimkasta's Avatar
I am also looking for a motor and a good candidate seems to be spit-roast rotating motors. I can find them locally for around 5-10 euros
Old 20th January 2014, 03:39 PM   #505
Here in Italy spit motor are typically 2 RPM (too fast). I own a syncro A.C. motor taken from a telescope mount which is 1 RPH (too slow).
Any help for suppliers of 5 RPH motor here in Europe?
Old 20th January 2014, 04:54 PM   #506
Bwaze is offline Bwaze  Slovenia
I ordered this:
Motor:
High torque Turbo worm Geared motor DC motor GW370 12V 0.6rpm
AC/DC wall wart:
Universal AC/DC Stabilisiert- Netzgeršt 230V - 50Hz 650mA mit 6 univ.steckern
I should get roughly:
1 minute an 40 seconds per revolution at 12V
3 minutes and 20 seconds per revolution at 6V
4 minutes and 27 seconds per revolution at 4.5V
6 minutes and 40 seconts per revolution at 3V
Directly at the motor shaft. I belive motor has enough RPM and torque to function at 1/4 of nominal voltage, but I have absolutely no idea if that's true. Well, if I will have problems with motor stalling or not starting at low voltage I'll use gears to reduce speed.
Old 20th January 2014, 05:31 PM   #507
dimkasta's Avatar
Hmm yeah I forgot to mention that I am going for the rotation schedule of the Audio Desk cleaner, which is 10rpm more or less
Old 21st January 2014, 08:38 PM   #508
Also started working on the cleaner since I saw them at the audio show in Las Vegas. Great forum with the helpful tips!
Only have trouble finding the right motor in Europe (or a supplier which ships to Europe for small orders and acceptable costs). Any members from Europe have a tip where to find the right motor, around 6 RPH?
Old 22nd January 2014, 01:47 PM   #509
This post explains why a continuous stay in the bath should be preferred and the rotation period around 5 RPH.
Old 22nd January 2014, 03:39 PM   #510
Ptb1 is offline Ptb1  Norway
Here is a picture of my cleaner:
I made myself a record cleaner Sclalars Analogue Source 231 20th February 2017 05:01 PM
My DIY record cleaner. mattjk Analogue Source 105 9th March 2016 04:05 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 03:28 AM
diy ultrasonic cleaner, not using bought unit 3GGG Analogue Source 0 10th January 2011 09:28 AM
Ultrasonic Parts cleaner... DIY??? pk386 Everything Else 1 10th May 2004 06:55 PM
Copyright ©1999-2017 diyAudio
